Leaking rear main seal - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
post #1 of 4 Old 03-17-2014, 10:05 AM Thread Starter
Changed oil today and noticed the rear main seal appears to be leaking. Last oil change less than 3 weeks ago there was no signs of a leak. Truck has about 100000km/60k miles on it anyone else have this issue? How long does it take a dealer to pull the trans and replace the seal? Leaking rear main seal-imageuploadedbyautoguide1395079465.158209.jpg
Sent from AutoGuide.com App
Buffalostroker is offline
post #2 of 4 Old 03-17-2014, 02:28 PM
hard to see in the picture, but ive seen a lot more front pump trans leaks than rear main leaks. warranty pays 6 hours.
Scumbag is offline
post #3 of 4 Old 03-17-2014, 04:27 PM
Quoted: 4 Post(s)
I would guess bad transmission pump as well. Not too much work to fix. Good luck.
Deerhunter4 is offline
post #4 of 4 Old 03-17-2014, 07:26 PM Thread Starter
Cool thanks guys. What's the consequence of leaving this for a couple weeks until I can get it looked at? Obviously I will keep an eye on fluid levels.
