tools required for water tube (coolant leak) replacement - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
post #1 of 6 Old 02-27-2014, 01:02 PM Thread Starter
Hey guys i believe i found my coolant leak and was wondering if anyone has done this replacement themselves? if so what tools did you use as far as socket sizes and so on. i did a search for coolant leaks 6.7's and couldn't find the info. thanks in advance
so far i have the part numbers and tools below plus a youtube vid.
bc3z-6a968-c
bc3z-9u469-a
jiffy tite disconnect 3/8
2011 CCSB FX4 KR white, 6" BDS/FOX lift, mini maxx, Rudy's EGR delete, banks CAI, 5" turbo back, 325/60 on 20" fuel octanes,road armor,amp steps
probable cause is offline
The Following 3 Users Say Thank You to probable cause For This Useful Post:
Heavy_GD (06-25-2014), probuilder (03-25-2014), ROCKET VAPOR (03-07-2014)
post #2 of 6 Old 03-07-2014, 11:32 AM
ROCKET VAPOR's Avatar
Quoted: 2 Post(s)
Great video!!!
ROCKET VAPOR is offline
post #3 of 6 Old 03-09-2014, 08:29 AM
probuilder's Avatar
Thank you for the video, that is the same problem that I am having with mine.
2011 F350 XLT, CC LB, 4x4, SRW, Powerstroke 6.7, Mini Maxx, Factory Remote Start added, Productivity screen added, All White.
probuilder is offline
post #4 of 6 Old 06-25-2014, 07:38 AM
Same leak for me too. As far as tools? Basic hand tools. My guess is it will take me about an hour or so to fix and cost around $20 - $30. No biggie.
Dutch + Tina
Bell, Bobo, Harley, Buddy (the dogs), E and Double E (the finches)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2013 - 24 • Nights Camped 2014 - 58 and more to come!
4x4Given is offline
post #5 of 6 Old 01-09-2016, 07:42 PM
Quoted: 8 Post(s)
Does anyone know if you can replace the fitting with the newer design using the metal hold down plate and bolt? I'm sure the coolant line would need replacing also?
cfiles is offline
post #6 of 6 Old 01-11-2016, 07:47 PM
Quoted: 2 Post(s)
I need to do mine too. Looks like i may have to remove the passenger side heater hose.
jlee9541 is offline
