Weird driving issues - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 10 Old 01-27-2014, 02:04 PM Thread Starter
Axis2011KR's Avatar
Truck has been running fine until recently I noticed that the squeal sound from my wastegate (truck is deleted and running open downpipe so it's very audible) wasn't happening nearly as often as before.
I noticed that it seems to sit at about 10psi at part throttle now unless I give her a little more gas then it goes up like normal to about 30-32psi if I hit it hard. It seems to be staying in higher gears now instead of downshifting nearly as much as it used to, i.e. at 60 in 6th when I hit the gas less than about half throttle it will lug it in 6th to accelerate instead of dropping to 5th like it did before. It feels weird to me because I'm used to it dropping gears and hauling a$$ when I hit the throttle instead of gradually accelerating. I have noticed a more black smoke lately when I hit it pretty hard but I attributed that to me spooling it up a little more then necessary to get it to downshift and go like I'm used to and it's been colder like mid 30's outside.
No codes of any kind, no irregularities other then what was mentioned above. If I put the pedal to the floor it will still blow the tires off her and get on down the road with a quickness!
UPDATE:
Looks to be a pre-turbo exhaust leak of some kind and a pretty big leak at that. The entire passenger side of my engine bay is covered in soot so there has to be something loose...now to try and clean up all that soot and then figure out where it's coming from... any suggestions or anyone have similar issues in the past?
Axis2011KR is offline
post #2 of 10 Old 02-07-2014, 07:37 AM Thread Starter
Axis2011KR's Avatar
Well I caved and took it to the dealership, supposed crack on the egr tube somewhere. I'll post up pics tonight because I told them to save the broken part(s) so I could confirm what really went wrong. They are trying to pull the no warranty card on me...
2015 F-250 King Ranch 6.7L CC FX-4
Fabtech 10" 4 Link with Coilovers/American Force Vector 22x12/Toyo MT 40x15.50x22
SCT+No Limit+FloPro
2011 F-250 King Ranch 6.7L CC 4x4 sold
H&S+S&B+Open Downpipe
post #3 of 10 Old 02-10-2014, 04:37 AM
Can u just pull the egr out? Delete the whole thing? Why take it to the dealer and pay if you are dpf deleted?, sounds like ur engine wants to spit it out!
2012 f250 Ultimate Lariat, 6.7 powerstroke
Hunter69 is offline
post #4 of 10 Old 02-10-2014, 05:33 AM
fordtrix's Avatar
Do you think they should fix it under warranty?
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #5 of 10 Old 02-10-2014, 05:40 AM Thread Starter
Axis2011KR's Avatar
I could have just fully deleted the EGR but my truck was already in the shop so I either had to eat the assessment fee of $90 + the time to go pick it up and take it to another shop, order the delete which runs about $160, then pay another shop to install it because I don't have the time right now. I would have been out more money then just having them replace the cracked pipe for $375 total.
I think they absolutely should have considering I've never tampered with my EGR in any way other then turning it off with my tuner. That pipe shouldn't be cracked at random and/or the gasket shouldn't have been leaking, and since it's an engine part (100k powerstroke warranty) they should have covered it. I'm at 54K.
Regardless at this point, the issue is resolved and the truck is running like a champ again.
SCT+No Limit+FloPro
post #6 of 10 Old 02-11-2014, 08:25 AM
30-32 psi?? Is that typical of stock? The MOST I have ever seen since installing a monitor is 21-22 psi on my 2014 (and approximately that much before when looking at the stock gauge). That said, I've been wondering if I have a leak somewhere due to various noise and performance issues. I only have 3000 on the odometer right now, and the dealership kind of shrugged it off. I will have them look it over again when I go in for service in a few thousand.
2014 Tuxedo Black, 6.7L Lariat FX4, Nav, 20" aluminum wheels
siver_pilate is offline
post #7 of 10 Old 02-11-2014, 08:58 AM
Got it, makes sense.
Hunter69 is offline
post #8 of 10 Old 02-11-2014, 10:12 AM
fordtrix's Avatar
His truck is deleted, not stock. My psi is similar to yours, also as stock.
fordtrix is offline
post #9 of 10 Old 02-11-2014, 10:16 AM
Good to know. Thanks!
post #10 of 10 Old 02-12-2014, 10:29 AM Thread Starter
Axis2011KR's Avatar
^^This. Yeah stock should be 20-22ish
SCT+No Limit+FloPro
