Both coolant systems leaking. Places to check? - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 2 Old 10-17-2013, 10:55 AM Thread Starter
A while back while towing (accidentally on hot map) I blew my charge air cooler pipe. I roadside repaired it with duct tape and limped home on low boost. Replaced pipe with another stock unit. Since then (at least this is when I started noticing it) my primary AND secondary coolant tanks have been low. I keep topping them off with the 50/50 special coolant. Does anyone have any suggestions on where to look for a leak. I know people have said the bottom corner of the radiator is a problem, checked and nothing. Are there other places to look?
yupitsnuge is offline
post #2 of 2 Old 10-17-2013, 10:58 AM Thread Starter
