crank, no start - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 11 Old 05-27-2013, 11:07 AM Thread Starter
Made In America
Guardian29's Avatar
Angry crank, no start
Took the truck mudding yesterday, went through a pit that was a little borderline. Anyways wheeled for another hour or so and then on the freeway home about 10 minutes into the drive I notice oil temp climbing, caught my eye at 210, 2 minutes later its 230 then 240 and she dies. Almost as if you run out of fuel, just lost power then coasted to the side. Turns out air filter was f'd it was litrrally warped and wet and dirty. So we let it cool down and still mo start. Even at oil temp back to 150 stillcranking but wont fire.
Towed it home. Low voltage from cranking. Noticed oil on the bottom of the motor. Changed the MAF sensor, disconnected batteries for a bit. Now have code P2291 - injector control pressure too low - engine cranking. Checked fuses. Almost sounds as if its not getting fuel. And I wondered if the MAF could sense no air so in turn stops fuel flow. I have fuel flow to the filter under the hood. Had the charger on it, plenty fast crank. Sat all night and this morming went and tried it cranked and ran for about 15 seconds very rough then died and back to the same symptoms.
PHIL
'12 F250 CCSB, 35's, MiniMaxx, Deleted (Currently OOC)
'97 F350 CCLB, 6" Skyjacker w/ BDS and 35s, BTS tranny and HPOPs, 4.10s, H2E and stage 2 injectors, FASS 150, Banks intercooler, ARP head studs, IDM mod, DP tuner, WARN hubs, 6637, rear airbags
Guardian29 is offline
post #2 of 11 Old 05-28-2013, 04:46 PM
john galt's Avatar
Quoted: 125 Post(s)
I would be the wrong guy to ask here but I would be real nervouse about that air filter and would be checking to see if it could have sucked water/mud into your intake.
after that i would be worried about water damage to the ficm or something like that but that could be because of my ficm being out right now.
PLUS as I said I am NOT the guy to ask but perhaps someone smarter than myself will be along to correct me and point out something
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 11 Old 05-28-2013, 05:08 PM
tekemp's Avatar
I would locate the source of your oil leak first and also check the connection at the fuel rail pressure sensor...your crank no start/ rough idle sounds very similar to the sensor being unplugged.
2012 F-350 CCLB XLT/EGR/WEATHERTECH/RIGID/CTS/
tekemp is offline
post #4 of 11 Old 05-28-2013, 05:51 PM
check the throttle actuator to make sure its not stuck closed. I have heard that some people simply remove the blade fromt he shaft.
poormanscat is offline
post #5 of 11 Old 05-28-2013, 05:52 PM Thread Starter
Made In America
Guardian29's Avatar
Dropped the oil pan and nothing but metal. Waiting on approval from deerborne for a motor....
Sent from my DROID RAZR using AutoGuide.Com Free App
PHIL
post #6 of 11 Old 05-28-2013, 07:22 PM
Fox Hunt's Avatar
Quoted: 8 Post(s)
Ouch..... Any clue what happened?
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #7 of 11 Old 05-28-2013, 07:31 PM
I would bet its the rod bearings, that is what has been going on these.
Not sure why you got the low rail during cranking code.
But here is a link to some helpful info on that.
6.7 Powerstroke high pressure fuel diagnostic
cfd_shop is offline
post #8 of 11 Old 05-29-2013, 04:18 PM
john galt's Avatar
Quoted: 125 Post(s)
see. I KNEW someone smarter than me would be along.
thanks tekemp.
post #9 of 11 Old 05-29-2013, 06:29 PM Thread Starter
Made In America
Guardian29's Avatar
Talked with them today. Still havent pinpoited it yet. When I called they were checking the fuel system to see it it over fueled and hydro locked. I just hope I dont run into any warranty issues having the tuner.
PHIL
post #10 of 11 Old 05-30-2013, 12:25 PM
You'll be lucky if you don't have any issues. GM is pretty stingy on the duramaxes that come in with EFI live or H&S tuners.
Jon5212 is offline
