Turbo Surge - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 26 Old 05-06-2013, 03:09 PM Thread Starter
Turbo Surge
I have a 2012 6.7 with only 2,300 miles on it. (bone stock) I havn't driven it much,but now I am driving it every day. Anyway around 1,500 miles I noticed while going up long grades up the Interstate I drive every day that the needle on the boost guage will jump up and down about 3 to 5 pounds. It is real hard to actually feel the small surge that is taking place as well. If you are not on a smooth road or have the radio on you may not even notice it. The Tach metar does not move with the surge. It stays the same,but like I said the boost guage is the one going up in down.
I was at the Ford dealer the other day and told them about the TSB that Ford put out (TSB 13-04-03) about this problem I am having. I found out about it on this forum. They reprogrammed it and the problem is still there.
I have read about the problems on the 2011 and I would assume that even though my truck is a 2012 it would fall into the "problem areas" when it comes to Turbos because my truck was made in the early part on 2012 (Feb)
So my questions are:
Did everyone with the bad turbos have to wait until they blow before they were replaced?
How much boost are these 6.7's getting. I've only ever got 20 lbs. at wide open.
Do they take the cabs off to replace the Turbo? Looks like a mess to get to. How long would I be without a truck while replacing?
Jason1Pa is offline
post #2 of 26 Old 05-06-2013, 05:32 PM
I have a 2011 and I have noticed that the turbo surge has gotten to be pretty regular. I have almost 25,000 miles on mine. Last night I was driving at I had the radio down so that I could hold a conversation. I am wondering the same thing as you. Is it a sign that the turbo is about to blow, should I be worried about it? I never noticed it till I got my truck back from the dealership, they had to update the PCM if I remember correctly. So I am wondering if that might be the problem.
Tuxedo Black 2011 F-350 Lariat CCSB Loaded with everything. 4" BDS with Fox Shocks on Chrome 20x12 Fuel Throttles on 35" Fuel M/T's, double limo tint on the rear windows, and 25% on the front, AFE Stage II Intake, H&S Race Tuner, 5" Flo Pro.
http://www.facebook.com/benwgar
Ben_Garrett is offline
post #3 of 26 Old 05-08-2013, 11:39 AM Thread Starter
I forgot to say that I am only experiancing this issue when I have the cruise control on and I have it set lower then 60mph. As soon as I set it past 60mph I don't have the surge. Is your surge taking place just by using the peddle?
Jason1Pa is offline
post #4 of 26 Old 05-08-2013, 02:25 PM
Yeah, its just by using the pedal when ever I am just cruising. Tried to get it to do it today, by stepping on the pedal and then letting off real quick once boost was built. But it did nothing.
post #5 of 26 Old 05-08-2013, 04:21 PM
Lococoin's Avatar
Send a message via MSN to Lococoin
Is it surging or just increasing the boost then back down. Oscillating or fluctuating of the boost Guage would be how I'd describe mine. My June 2012 build does that in cruise between 60 and 66 Mph sometimes. I've had it in and they say it's a normal charactistic of the truck. To me it seems like poor programming under certain loads and i hope they can fix it one day if enough people complain.
Oh and the most boost I've seen is just over 20.
Lococoin is offline
post #6 of 26 Old 05-08-2013, 04:53 PM Thread Starter
I guess I maybe shouldnt use the word "surge" it is more just a rapped increase and decrease of boost multipul times. The RPM does not change. It is real hard to notice it. If someone was talking or had the radio on it may be missed.
Jason1Pa is offline
post #7 of 26 Old 05-08-2013, 05:26 PM
Has anyone logged data on this.
I would like to see exhaust backpressure and turbo vane control solenoid duty cycle, egr on/off and maf airflow.
That would give us a better idea of whats going on.
cfd_shop is offline
post #8 of 26 Old 05-08-2013, 05:36 PM
Lococoin's Avatar
That's exactly what mine does and a ton of people complain about it. Just Google 6.7 Cruise control Surge. I even asked my buddy with a 12 If his did it. He never noticed before but once I pointed it out then he noticed his does it too. Dealer and ford customer service say it's a "normal charactistic of the truck" which is a cop out in my opinion.
Lococoin is offline
post #9 of 26 Old 05-08-2013, 05:37 PM
Lococoin's Avatar
I took a quick video of mine doing it the other day.
https://www.youtube.com/watch?v=4MgC...e_gdata_player
Lococoin is offline
post #10 of 26 Old 05-09-2013, 04:13 AM
Lococoin's Avatar
I need to order the dongle for my autoenginuity so I can get a newer version of the software. I do have the ford enhanced so I would think I could record this info but I'm not 100% sure.
Lococoin is offline
