Won't Start with Key but Starts with Remote - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
 1Likes
post #1 of 23 Old 04-05-2013, 10:52 AM Thread Starter
I have a 2011 Ford F250 6.7 Liter Diesel it will only start with the remote, it has 35,250 miles on it. I am wondering if anyone has had this problem and what was done to fix it? It has been in the shop now for 5 days and they can't seem to figure out what is wrong with it. They are throwing parts at it to try and fix it and so far none have worked. They've changed the starter, inspected the fly-wheel, changed a modular box and have now ordered a PCM module whatever that is. Now my question is on the starter and Fly-wheel why would it be mechanical when it works with the remote and not the key. To me it would be electrical or computer. If anyone has any help it would be appreciated.
Thanks,
Chris
chrisc291 is offline
post #2 of 23 Old 04-05-2013, 10:24 PM
ToyoTundra11's Avatar
Does your steering wheel electrically telescopic. I had one at work 12 sequoia did the same. Wire rubbed through and shorted out at column
ToyoTundra11 is offline
post #3 of 23 Old 04-06-2013, 07:18 AM Thread Starter
Update:The Ford Dealer now has gotten the truck also not to start with the remote. When the problem happens the motor starts to crank but does not completely turnover it just stops. They also said oddly enough they have another truck doing the same thing. It's the same year but has 60,000 miles on it. This truck is throwing a code saying to replace the PCM module so they are going to try that on mine as well on Monday. I will post update Monday on results.
post #4 of 23 Old 04-07-2013, 03:50 AM
brstanle's Avatar
I was going to say to look at your key and make sure it's not worn out, but you would be the punisher of keys for that to happen that fast.
brstanle is offline
post #5 of 23 Old 05-04-2013, 05:20 PM
Jakeman711's Avatar
Wow, a bad PCM already. The brain of the powertrain went bad. Wierd. I have see this in other vehicles and it ended up being the ignition switch, but I don't know much about the 6.7 equipped trucks. The Ford tech would know more than I would, and I am not being condescending.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #6 of 23 Old 07-26-2013, 02:07 PM
Any update on the final disposition? I seem to be having a similar issue.
combatkenpo66 is offline
post #7 of 23 Old 07-28-2013, 10:18 AM
We have seen a few bad electrical connectors on the PCM (power control module) here lately that people were getting a no start condition, worth the look.
2011 F-350 CC LB SRW Larriet 6.7 PSD with a limited edition rear end bounce @ 43 mph.
thom12 is offline
post #8 of 23 Old 04-24-2014, 04:32 AM
My 2011 6.7 is doin the same thing. Sometimes it starts sometimes it doesn't. Last night it did this andi finally got it to start with the remote.
2011 f-350 4x4 crew cab dually
2.5 inch lift on the front
Air bags on the back
200 hp
War hammer spartan and the dpf/cat delete
150 db - 150 psi train horn
Weather tech floor liners
Brand new flat bed
Mattress Guy is offline
post #9 of 23 Old 04-24-2014, 04:35 AM
Quoted: 48 Post(s)
are you guys getting a DTC? had an '11 doing this that had an ECM shutdown code. put a new passenger side battery in it, and it's been doing fine since. That was 50k miles ago
drunk on diesel is offline
post #10 of 23 Old 05-07-2014, 08:44 AM
Hooked on the POWER...
allenhood71's Avatar
Feedback Score: 6 reviews
Mine started this today. I am not getting any codes. But talking with my ford guy he said to try the batteries first and we will go from there. I will update.
allenhood71 is offline
The Following User Says Thank You to allenhood71 For This Useful Post:
jrlopez (06-14-2015)
