BAD 6.7 HELPPPP!!!!! - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 12 Old 03-24-2013, 07:58 PM Thread Starter
Question BAD 6.7 HELPPPP!!!!!
i have a srw 2011 f350 6.7 yesterday i was towing about 30k pounds and it all of a sudden made a noise and started missin real bad and a little black smoke turned in to alot of blueish whiteish smoke it make a small knockin sound when it first happend for a little bit then that stopped made it back home and dropped the load and took it to ford had them plug it up and they said it dropped a valve and has a number 6 missfire so i took it home and oulled the valuve cover off and the valves looked and felt fine so i have the motor ready to pull out i have a h&s programmer that was turned off whn it happned and it has a straight pipe but i dont think that has anything to do with it but it has 165000 miles on it i think it could be a broke ring anyone have any advise??????
bamapower is offline
post #2 of 12 Old 03-24-2013, 08:12 PM
powerstroke4713's Avatar
Pull #6 glow plug and see if its broken. You will need a Craftsmen 8mm deep 1/4 drive to remove the glow plug. There is a TSB from Ford for this concern. TSB 12-11-11 6.7L diesel engine and built on or before 3/29/2011
powerstroke4713 is offline
post #3 of 12 Old 03-25-2013, 06:38 AM Thread Starter
Ok so I sould probaly do that be for I finish pullin the motor
post #4 of 12 Old 04-11-2013, 07:05 PM
had this once on a tow truck early build.seen them drop vlvs and make piston to head contact.not sure if u having this problem but seen this happen twice at our dealership.pull the glow plugs and see if any are broken if not u might want to pull the heads,then u can c if the vlvs are ok mght seem fine looking at them w the vlv covers off.but as soon as u take off the heads pieces of vlv material start to fall off.!!
htownracer is offline
post #5 of 12 Old 04-17-2013, 07:00 PM
yep, it happens .. dang... how do u already have 165,000 miles on a 11 model..??
poormanscat is offline
post #6 of 12 Old 04-18-2013, 11:05 AM
165,000 is pretty impressive for a newer engine design. Makes me feel better about my new 2013.
Diverb is offline
post #7 of 12 Old 04-26-2013, 10:47 AM
Just shows how tough these trucks really are.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #8 of 12 Old 04-27-2013, 10:00 AM
truck would have to run non stop to get 165,000 that quick...
post #9 of 12 Old 04-27-2013, 11:02 AM
usnavyad's Avatar
Feedback Score: 3 reviews
Wow that is impressive 165k
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #10 of 12 Old 04-30-2013, 08:45 PM
desertnomad's Avatar
What's even more impressing is towing 30k lbs! Seriously?
2012 F350 6.7L 4x4 Lariat Ultimate FX4, Chrome package, Nav, SRW, CC, LB, 11.5K GVWR, 3.55 ELA, Toyo MT, Duraflaps
2009 Carriage Cameo 35SB3, 12.4K dry, 36' Fiver
desertnomad is offline
