2012 6.7 dpf failure and exhaust fluid system failure - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 10 Old 03-08-2013, 05:51 PM Thread Starter
Smile 2012 6.7 dpf failure and exhaust fluid system failure
I have a 2012 F250 6.7 that has on it 29k miles i have installed a banks ram air and banks exhaust from the dpf back. I have had these two mods installed since the vehicle was new. The truck had no emission system issues until about 27k miles then I had 5 error for the exhaust fluid system. The truck has been out of service on and off for about 10 days and ford has not yet solves the issues. Ford is claiming that the banks ram air has damaged the system. which i can not believe. Now i have a cracked dpf which they claim was damaged by the banks ram air. Ford will do no more testing until i return the air intake to factory stock. I will do that now and see where this goes. i am also concerned about an emission systems putting the vehicle in limp mode. I feel this is unsafe and totaly unreasonable. Right now Ford will not warranty the dpf. Any comments or feedback would be appreciated
triarr is offline
post #2 of 10 Old 03-08-2013, 06:19 PM
BIG Laing's Avatar
I hope they end up covering it for you, I don't see how either of your mods could cuase those issues. In the future return your truck to stock before taking it into the dealership. I have heard of them denying warrentys, for an exhaust tip before. It is of them to do it to loyal customers!
If they do not cover anything, it will probably be a helluva lot cheaper for you to get a tuner like Spartan (or H&S race tuner if you can find one) and just get rid of all the emmisions crap.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 10 Old 03-08-2013, 08:10 PM
Alberta Advantage's Avatar
Quoted: 17 Post(s)
My truck is stock ('09) and I had the DPF replaced at the 30,000 mile service because it was cracked. There's been a few cases of cracked DPFs on the 6.4 trucks with even fewer miles than mine. If warranty didn't cover mine I would have deleted. The DPF in Canada is ~$2700 plus labor. It seems like dealerships hate to do warranty work as they aren't paid as well as straight labor and parts. Warranty shafts them on the reimbursement so it isn't worth their time. Any way to deny a claim or get you to leave is what they seem most interested in.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 10 Old 01-29-2014, 11:29 AM
I have a 2012 6.7 (unmodified)(25509 miles) has been in shop 5 times for the DEF defaults. Reflashed/sensors replaced and entire DEF unit replaced 1900 miles ago--just towed off again for the 2nd time in 30 days--to Homestead, Fl. 3 hours from my location in Key West with me footing the tow bill up front--looks like this is my last Powerstroke after the last 7-8 I have purchased!! Ford has NO CLUE on how to handle a 35 year customer!! When they needed to replaced the unit they told me they could not get the part until 2/14/14. Melbourne has been useless!!
Irish Fin is offline
post #5 of 10 Old 01-29-2014, 02:45 PM
fordtrix's Avatar
It's going to be hard when the manual states those items may void your warranty.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #6 of 10 Old 03-08-2014, 08:42 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
Where in the country are you ?? I got the placer part if its placer anything is CA ill sell you all my stock stuff DPF intake bla bla bla for an extremely reasonable deal or ill help ya delete hahaha
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #7 of 10 Old 03-09-2014, 06:07 AM
unfortunately, anything you do can/will void your warranty.
poormanscat is offline
post #8 of 10 Old 03-09-2014, 06:56 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
It's going to be tough getting it warrantied, good luck tho.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #9 of 10 Old 04-18-2014, 04:18 PM
drewguy363's Avatar
Save yourself anymore headaches.....DELETE!!
'13 F350 CC LB Platinum
Full HID's
B&W Turnover Ball w/ companion
4" Zone lift with control arm upgrade
drewguy363 is offline
post #10 of 10 Old 05-16-2014, 09:49 PM
my 2010 f450 craked a DPF and it ran wonderfully until i deleted it. it would only regen every 2,000 miles. i only deleted because i got a dpf delete for my birthday!
2012 f250 deleted
2010 f450 deleted
2000 hummer h1 stock
1996 hummer h1 4" straight pipe
Zooky is offline
Tags
6.7 dpf failures , 6.7 emissions
