Water in fuel light not turning off. - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
Old 02-09-2013, 01:36 PM
Hello all,
I have a 2011 F350 6.7 with approx 22,000 miles. I have had issues with the water in fuel light. When it first came on I followed the procedure in the owners manual, never noticed any water in the fuel, and the light went out. It seems to come on more when the climate is damp, rain and snow. Every time I have ever drained the fuel, I have never noticed any water.
I have had the fuel filters changed three times since I have owned the truck. Always by the dealership and with Ford filters.
The last fuel filter changed occured approx 2 months ago at Buhler Ford in Eatontown, NJ.
The light came on last night and I drained the fuel, again with no water observed. The light would not shut off and engine power was reduced. I again dained fuel this morning 02/09/2013 and no water was observed. The ligh would still not shut off.
I took the truck back to the dealer. The non diesel tech looked at the truck and found a plug that was unplugged from the fuel filter area under the truck!
Im guessing what ever tech did the last change out forgot to put the plug back in?
He found a code that said it could be that the water in fuel sensor could be faulty or the fuel could be contaminated???
He also said that all additives in the 6.7 are no good and not necessary. I have been running Stanadyne additive in my truck since it was new andhave never had an issue?
Has anyone else had a similar problem? Please help
Old 04-08-2013, 08:10 AM
Yes I just had a similar experience. I have a 2012 f350 6.7 with 45,000 km on it. I was driving home from the mountains when I got a water in fuel warning. It had just snowed and there was a lot of slush and water on the highway. It was just below freezing so there was a lot of ice buildup on the truck. I pulled over and drained the dfcm twice and and no water came out but the light wouldnt go out. I drove to my shop and drained it 2 more times and no water in fuel but got the reduced power light also. The next morning started it up and no change, so while I was driving to the dealership the light goes out and and everything returns to normal. I am thinking it was all from the excess ice and snow buildup. Does anyone know if this can happen or was there actually water in the fuel? Will it set up a code or is it just a warning and return to normal once drained? I will be going in soon for an oil change and will have them check it out and keep you posted. Thanks.
Old 04-21-2013, 06:43 AM
Did they also drain the water seperator ?
