2011 6.7 turbo - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
User Tag List
post #1 of 6 Old 01-15-2013, 01:30 PM Thread Starter
2011 6.7 turbo
hi have a 2011 f 350 6.7 and have had the turbo replaced once because of a bad waste gate and 10,000 mile later it needs another one, but the dealer can find a problem so they wont replace it. i use my truch for landscaping and it acts up all the time i loose boost so my truck starts to buck. i have had more problems with this truck in one year then i have had with any used truck combined. ive had new hubs put on new blower motor, trans solenoids, turbo and know my dpf filter is bad but they dont know what one so they wont touch it. bs ANY ONE ELSE WITH SIMILER PROBLEMS
fordf3502011 is offline
post #2 of 6 Old 01-16-2013, 02:58 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
It sounds like you've got yourself a lemon. Thats way too many issues to have in such a short period of time. Start thinking about a lawyer and I hope it works for you. Rememeber, every brand has issues, if you really like your truck have them replace it and get one you can drive and really see what these trucks can do.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 6 Old 01-16-2013, 11:34 AM Thread Starter
i have gone directly through ford and they have filled for the lemon law and there lawyers say it does not meet the needs. yet the dealer says it should be bought back. this was the biggest waste of money i have every spent. the truck was $55,000 plus everythilng i have done to it for my work. after only one year they offered me only $32,000 on trade in. this whole thing makes me want to go back to my chevy's
post #4 of 6 Old 02-10-2013, 04:15 PM
Joe 6.7's Avatar
I have had turbo issues as well at 29500 jthe first blew and then again at 40000 now sence they replaced that the truck dies if idling to long and takes about 10mins for it to start. took it in they replaced a flow valve to the turbo and 3 days later it started dieing again it runs fine going down the road just if you stop and idle i dont know what the hell is going on kinda tierd of dealing with. love the truck though i hope they get it figured out if not lemon law here i come.
Joe 6.7 is offline
post #5 of 6 Old 02-26-2013, 07:13 PM
replaced turbo on my 2011 6.7 at 34,000, 37,000, 41,000, and now 52,000. the truck is bone stock. doesn't make much sense to me that they just keep replacing with the exact same kind of turbo....what happens when my warranty runs up? i also have the "death wobble" in the steering wheel and my dealership is dumbfounded....don't know how to fix. any input on what the heck is going on??
11fourfifty is offline
post #6 of 6 Old 03-20-2013, 05:22 AM
2011 6.7 turbo
Suggestion... Find a dealer w a tech that knows what they are doing!! 6.7 dpf is all one piece. It doesnt matter which one is bad bc it can only be replaced as a whole system!!
chris7686 is offline
