Loud idle noise - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
post #1 of 12 Old 01-15-2013, 07:04 AM Thread Starter
Quoted: 30 Post(s)
Loud idle noise
Here's a short clip I took of my truck idling this morning. I was shocked. I drove it to the diesel pump after to top off and I stepped out of the truck to listen for the noise but it had stopped. I was guessing it was the inlet intercooler pipe but everything is normal at the moment.
Here's the vid:
H&S MinniMaxx
5" Flo-Pro
S&B Intake
Carli 2.5" Backcountry w/Full Leafs
Balla6.7 is offline
post #2 of 12 Old 06-21-2013, 01:24 PM
F350KR's Avatar
HEY!!!! I HAVE THE SAME problem!! its coming from an electronic box thing that is mounted to the top of the alternator! has two small vac lines going to it. mine is just as loud as yours but get louder when the truck turns off. see video!!
did you figure your out? thanks
text me if you do. 2173580122 thanks
Had- 2004 F350 CC LB 4x4 6.0 Tuned, 4" Straight Pipe, K&N, LED strobes, Double DIN Dash Mod, 201,653 on the OD
Have- 2012 F350 King Ranch CC, H&S, Straight piped, Whited out grill, Readylift sitting in living room...
F350KR is offline
post #3 of 12 Old 06-21-2013, 01:42 PM
F350KR's Avatar
think the part making all this noise is the EGR Vacuum solenoid... having a hard time finding a new one...
F350KR is offline
post #4 of 12 Old 07-05-2013, 03:12 AM
F350KR's Avatar
Seriously!! Someone??? We can't be the only two making this noise
F350KR is offline
post #5 of 12 Old 07-10-2013, 05:07 PM
Did you figure this out ?
Horseshoezach is offline
post #6 of 12 Old 07-16-2013, 09:37 PM
Here is the noise mine is making. Slightly different from the second video and the first video is no longer available for viewing. Noise started at 4400 miles on the odo and I hope Ford can track it down properly.
F350 6.7L noise - YouTube
Rig:
2012 F350 Lariat FX4
Toys:
03 Jeep Rubicon
04 21' Cobalt
bbusch is offline
post #7 of 12 Old 07-17-2013, 05:57 AM
Mine started doing this two days ago but, only after shut off. Just called the dealer and there is a TSB for the Waste Gate Solenoid. I'm taking mine by there tomorrow for them to look at it and write something up to cover myself.
Lowbudgetracer is offline
post #8 of 12 Old 07-18-2013, 09:23 AM
Kinda sounds like what my C&C truck sounded like when the little exhaust pipe bellows cracked.. Mine cracked to the top and melted the windshield washer tubing off the bottom of the hood.
poormanscat is offline
post #9 of 12 Old 07-30-2013, 08:08 AM
Well I took mine in and the Service Bulletin claims Electronic Waste-gate Solenoid is what's making the buzzing noise. They don't replace this cause the smart engineer claims no damage can result from this. Well after a week and a half this this is now making the noise loud when I'm driving it. It sucks cause I did not spend this type of money to hear this crap.
post #10 of 12 Old 07-31-2013, 06:34 PM
Unplug wastegate solenoid, take two 12v batteries and wire them in series, fabricate two small jumper wires and short out the WG solenoid, connect the wiring back up, and call the dealership. Problem solved!
