| 6.7 Motor Problems 6.7 Motor Problems |
How difficult is it to replace the turbo
My turbo bearrings went out with 45K miles. Ford denied my warranty cause I am Spartan tuned. The Ford house wants to replace it for $3650. I believe the new turbo cost $2000. Is there really $1600 worth of labor involved in replacing a turbo or is it something I can do on my own in my driveway? Any help would be appreciated.
I'd say you could probably do it. That place is sticking it up your hind side on price!!!!
The turbo can be had for $1329 here: 2011 FORD F-350 SUPER DUTY Parts - Tousley Ford Parts Depot tousley ford parts is the bomb!!
When I placed my order with them for a upfitter switch they called me to make sure I was ordering the correct part. I received my order the next day. |
Why not ask Spartan to cover the cost of your new turbo? It is apparent from the much higher percentage of turbo failures on tuned 6.7s, that the tuner is over stressing the Ford turbo. This would indicate that the tuner manufacture did not do adequate testing on the negative effects their tuner could have on the stock 6.7 prior to marketing their product.
The turbos on the new 6.7L are weak... Ford would not have voluntarily spent the $$$ on updating the turbo components for the newer trucks if there wasnt an issue. |
Personally? No.. The turbo on the pickup engine is of marginal durability as well. I would imagine that if you check shaft speed of the turbo with the engine at full power at sea level, then again at altitude, you would most likely find the answers to the 6.7L altitude sickness.
If the turbo was not at the edge of its operating window in stock form, a tuner would not have hurt it. Ford/Dealerships simply use the tuner as an excuse to not pay for a marginal design. Along the same lines as blaming a CP4 pump failure on "bad fuel" I have a very good friend that has a 12 model F250 that shelled out the turbo before it hit 5K miles, stock, not over/under worked... Just rolled thru a light and went back to the throttle and bang!. These reports are all to familiar.. While you can't necessarily compare different engine manufacturers, my 5.9L has been running a tuner for several years and is always running well beyond the factory IMAP specs... no failure yet |
With regard to the reported 6.7 altitude sickness, my stock 6.7 has had no problem pulling my travel trailer (12k) through the Eisenhower Tunnel on 3 trips back east during the last 2 yrs at the speed limit. Anyone who can not do that should have their truck checked for a problem. Could the 6.7 do it at 15k ft altitude? Don't know don't care. |
There is a reason Ford has spent development resources updating the turbo for late 2012 and future engines... They do not spend $$$ just for the fun of it.
Back in mid-late 2010, I stood in a local dealership service department among 3 Ford engineers as we all discussed the large # of random issues we were experiencing with our early release 2011 C&C trucks.... When the subject turned to the turbos on the C&C trucks I inquired as to why they did not use the pickup turbo on the C&C truck and was told there had been an extraordinary amount of time and resources sizing the turbo for the pickup trucks, and in the end, they were still not completely satisfied with the production part.... This conversation initially started due to inquiries as to why the pickup had an exhaust brake and the C&C trucks did not. In the end, when a consumer purchases a tuner for any vehicle, they take all responsibility into their own hands and should assume they have become their own warranty station.... Spartan did not force anyone to buy their product! |
I wished the supposed exhaust brake that these pickups have would actually apply stopping power.
