Sputtering sound? - Page 5 - Ford Powerstroke Diesel Forum
6.7 Motor Problems 6.7 Motor Problems
 2Likes
post #41 of 118 Old 03-01-2011, 01:21 PM
PMR = JUNK
Jake's Avatar
Quoted: 2 Post(s)
Originally Posted by Joe 6.7 View Post
It just keeps the truck from over boost. It is called a WASTE GATE. The truck is just doing its job. I dont find this being a problem it does this in cruz control. It is a completly different engine to the rest.
Wrong. A wastegate should NOT make noise, or make the engine power surge.
Originally Posted by 11stroke67 View Post
thats what i was thinking when i first heard it. ford or dealers should tell people that the new motors make these noises so nobody panics when they hear it. i have a buddy that has a semi with a cummins in it and he said it does the same thing when building boost before the motor is ready to handle it. hopefully this will mean no more stretched head studs like on the 6.0
Ford dealers don't tell people about these noises because they aren't supposed to make noises like that.
Your buddy's semi that makes a noise when building boost before the motor is ready to handle it is gonna destroy his turbo. That is turbo surge. Look that up and tell me if you think its a good thing.
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #42 of 118 Old 03-06-2011, 12:47 PM
DieselJoE26's Avatar
Send a message via AIM to DieselJoE26
I do know that FORD is investigating the turbo noise, I am a ford Diesel tech. I read something on the FORD website a couple days ago, and it said they were still investigating it.
I my self havent had a truck come in with that concern, but i do know that the 6.7 turbos do have a VGT valve on them. Sounds like maybe a VGT valve is sticking.. But its not the waste gate, i know that for sure. If im correct it probably sounds like the 6.0 turbo flutter noise, right?
DieselJoE26 is offline
post #43 of 118 Old 03-15-2011, 08:47 AM Thread Starter
relentless1's Avatar
Yeah def not the WASTE GATE there big guy. thanks for the adament and somewhat nasty response though. I wish you were right.
2011 F-350 S/C Lariat
2.5" Icon Leveling kit
HID headlamps and fogs
AFE stage 2 Intake
BMF S.O.T.A Deathmetal Black 20"
Toyo Open Country MT's 35"
relentless1 is offline
post #44 of 118 Old 03-15-2011, 02:30 PM
PMR = JUNK
Jake's Avatar
Quoted: 2 Post(s)
Who was that directed at?
BPS President
Jake is offline
post #45 of 118 Old 03-15-2011, 11:08 PM
Joe 6.7's Avatar
So If Im going up hill pulling a trialer staying at the same speed I notice the boost rise and then drop in sperts but maintain the same power and speed thats not a waist gate disposing boost I no longer need. Just asking becuase then I need to let frankie at jim burke ford in bakersfield know his a lier.
Joe 6.7 is offline
post #46 of 118 Old 03-16-2011, 11:33 AM
DavidPhillips's Avatar
My 6.4 makes the same noise that it sounds like your describing. I really only notice the air sound if the engine is shut off while the turbo is spinning. Sounds like the compressor is pushing air but it is not being allowed to exit through the engine. It could also be the turbine making the noise in the exhaust cavity although I seem to think it is in the intake side for some reason.
Waste gate controls the turbine speed. If the waste gate is bypassing the exhaust or there is a decrease of exhaust this would decrease the turbine speed and drop boost. In the situation being described it seems to be as the engine is slowing down or the load is decreased. It's not the waste gate making the noise but that's not to say that it is not caused by the action or inaction of the waste gate.
I would not consider it a problem. It's just a characteristic.
All my touring photos. (except the two massive trips in 2011-soon to be posted eventually)
http://photobucket.com/OneHorseRally
Coastal Maine road trip 2007
Alaska tour 2008 - 14,000 miles in 28 days
-david
/ 2011 F250 4x2 Crew Cab /
Replaced "The Beast" 6.4L with 75,000 miles. Hated to see it go.
DavidPhillips is offline
post #47 of 118 Old 03-16-2011, 12:50 PM
PMR = JUNK
Jake's Avatar
Quoted: 2 Post(s)
How fast are these sperts? If its really rapid then your dealer is full of chit. A wastegate has smooth operation.
BPS President
Jake is offline
post #48 of 118 Old 03-16-2011, 01:32 PM
Joe 6.7's Avatar
Almost a turbo fart sound kinda like when the 6.0 is at the end of a sled pull. You can watch the boost gauge drop little by little then it will stay and it only does it if you stay at a constant speed.
Joe 6.7 is offline
post #49 of 118 Old 03-16-2011, 02:48 PM
PMR = JUNK
Jake's Avatar
Quoted: 2 Post(s)
If it is anything like these videos, it is bad. Compressor surge.
BPS President
Jake is offline
post #50 of 118 Old 03-16-2011, 04:08 PM
Joe 6.7's Avatar
No nothing Like that.
Joe 6.7 is offline
