Another 6.7 Engine Failure - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
 18Likes
post #1 of 182 Old 01-08-2014, 10:52 AM Thread Starter
bigred_stroker's Avatar
I have seen a few posts on 6.7 engine failures. I just took a call from the ford dealer working on my truck saying it was a catastrophic engine failure. I will post more once the engine is torn down and more is know.
As for the event itself. It happened while driving down the highway. Cruise was set at 70. Truck has never been tuned and has always been meticulously taken care of. 61,000 miles. Go figure it happened right after the bumper to bumper expired. It started with a downshift, vibrated and started knocking then lost all power and oil pressure.
We will see where it goes from here. I had all maintenance done by ford except for the last two oil changes which I did myself and made records for.
mjm97stroker likes this.
2011 F-250 6.7L FX4 Lariat CCSB Tuxedo Black, Black Leather, 6" Lift w/ 37" Nitto trail grapplers 20" XD rims.
bigred_stroker is offline
post #2 of 182 Old 01-08-2014, 01:07 PM
There is a cure: DMAX! I work with a 2005 GMC HD and an 08 Chevy HD that are routinely overloaded, towing over 30K lbs. Both have over 100k miles. Neither have ever broken down.
Magirus is offline
post #3 of 182 Old 01-08-2014, 01:12 PM
Quoted: 6 Post(s)
Wow you are funny!
6viagra6 likes this.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #4 of 182 Old 01-08-2014, 01:26 PM
Subscribed
Gbhtrd06 is offline
post #5 of 182 Old 01-08-2014, 01:35 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
ummm............................
lol this is a ford/powerstroke forum. Dont try pulling that crap
Trucks and parts............
kanuck15 is offline
post #6 of 182 Old 01-08-2014, 03:30 PM
6liter_BigSkyStroker's Avatar
Subscribed
2005 F250 SuperDuty, EGR Delete Kit, Head Studs, 4" MBRP Turbo Back Exhaust, Cat Gone, BATMOWHEEL, S&B Cold Air Intake System, 18" Wheels, Swamps 58V Hot FICM
, AND SCTX3 Tuner with 3 custom tunes! Thanks Eric at Innovative Diesel
6liter_BigSkyStroker is offline
post #7 of 182 Old 01-08-2014, 03:44 PM
Quoted: 2 Post(s)
Why would you join a Powerstroke Forum, then??????????
Go find somewhere else to play, Junior!
Truckmaniac is offline
post #8 of 182 Old 01-08-2014, 04:12 PM
Well good thing the engine and power train is covered till 100,000 then huh? Emissions only go till 60,000. Mine blew a head bolt and cracked exhaust manifold and even though I'm deleted dealer still covered it at 70,000 . You shouldn't have an issue since your still in warranty
2011 F350 DRW lariat Spartan tuned, 4" straight piped exhaust,afe stage 2 CAI,SDP egr delete and more coming
Sold 12 ram 2500 and dont miss it!!!
E99 F350 7.3L parts on the way
skinnysfd is offline
The Following User Says Thank You to skinnysfd For This Useful Post:
Urf250 (04-07-2014)
post #9 of 182 Old 01-08-2014, 04:36 PM
Quoted: 2 Post(s)
Your engine warranty is 100,000 miles, so you should be covered.
post #10 of 182 Old 01-12-2014, 05:52 AM Thread Starter
Update: I spoke with mechanic who said according to the tests run, it appears that a valve dropped in the #8 cylinder. Ford didn't want him tearing the engine apart to see the extent of damage. It wouldn't matter much anyhow. The new engine is ordered and will be put in this week. I have been happy with how this ford dealership has handled the service.
The mechanic was also going to check the turbo and dpf to make sure that neither needed replaced with the engine. I have not heard yet if either need it. The other good thing is that it will be a brand new engine and not a re-man. engine.
