I’m at my wits end with my truck… - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 24 Old 12-31-2013, 04:03 PM Thread Starter
Hi All,
I don’t post much here but I am an avid reader of the forum. I’m at my wits end with my truck…$68K (MSRP) truck and I have to put up with this I have a 2012 F350 DRW KR, 6.7 with about 9400 miles. I have had the truck about 11 months. I have read similar issues on this forum as I’m having just not quite sure if it’s identical. The issue began shortly after purchasing new. Here is a good example: I leave work and drive about 8 miles…engine is warm…I stop at the store for about 10 minutes…then crank up and exit the parking lot onto the road and stop t the red light…mostly just a high idle to get to that point. Turn right at the red light and when I begin to accelerate the engine almost dies…seems like it is almost sputtering…I let off the accelerator a little and it finally begins to run somewhat correctly. After this, it seems there is a loss of power for a while.
I have carried it to two different dealers…their answer is they can’t duplicate and therefore refuse to do anything The truck does the very same thing 98% of the time I stop. Even driving for 2 hours…stop at a rest stop…when I begin to accelerate as I’m leaving…same thing. It has done this one time while towing my camper.
Sorry to be long winded…any advice is very much appreciative.
Thanks in advance...Steve
2012 F350 6.7 CC DRW KR FX4 LB
2012 Raptor 410LEV
Ford_Highroller is offline
post #2 of 24 Old 12-31-2013, 05:31 PM
Quoted: 54 Post(s)
Damn that sucks to hear.. Have you tried getting a camera to record it? I had to do this with my Ford Fusion.. Which almost killed me once..
Sometimes it's worth buying a GoPro camera or something.. Or pulling out the cell phone to record.
I hope that it gets resolved buddy
2013 F-250 PSD - Carli 2.5" Backcountry - Fox Racing - BMF - Toyo RT's - Air Ride - AMP Research - Magnaflow - Royalty Core - Line X - H&S - No Limit Fabrication - Deleted - Tuned - 450rwhp/1000rwtq
98 Cobra - To many mods to list, 900+rwhp
98 Saleen Cobra is offline
post #3 of 24 Old 12-31-2013, 05:32 PM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
I have a 6.4L. I know its different, but before deleting, my truck really hated short commutes like the ones you mention. On my way to work I would stop at the store on my way to work or school and my truck will act similar to your 6.7 when I will leave the store. After reading through the forums, I learned that this trucks hate short commutes.
2008 6.4L powerstroke
cc sb Lariat 4x4
H&S XRT PRO, DPF delete,S&B intake, coolant filter, stock suspension
Stand therefore, having your loins girt about with truth, and having on the breastplate of righteousness Ephesians 6:14
'086.4LDiEsEl' is offline
post #4 of 24 Old 12-31-2013, 06:46 PM Thread Starter
Thanks "98"! I'm going to have to get something to record the behavior...it's driving me nuts! Afraid someone is going to hit me before this issue is resolved. I will see if I can get something on my phone for the dealer.
2012 Raptor 410LEV
post #5 of 24 Old 12-31-2013, 06:49 PM Thread Starter
Thank "086" for the response. The issue I have surfaces on short and long commutes. Could be turbo related...I'm just not smart enough on diesels to figure it out.
2012 Raptor 410LEV
post #6 of 24 Old 12-31-2013, 06:49 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Just throwing this out there, but if it is sucking air into the fuel system it will cause some weird stuff. Have the filters been changed yet?
dhanna6powerstroke is offline
post #7 of 24 Old 12-31-2013, 06:57 PM Thread Starter
Good point...I'll have the fuel filters changed. Could very well be the culprit.
Thanks for the response!
2012 Raptor 410LEV
post #8 of 24 Old 12-31-2013, 07:13 PM
luke7.3's Avatar
Quoted: 24 Post(s)
I doubt it's cold enough in Alabama.. but your descripion is similar t gelled diesel fuel.
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #9 of 24 Old 12-31-2013, 10:49 PM
jacobdewey's Avatar
I once had a traction control issue that sounded similar to what you are describing. Just a thought.
2011 CCSB, 20x9 -12mm Badlands, H&S, S&B, Katzkin, DDM 5k, 1.5" leveling kit, 35" AT II's.
jacobdewey is offline
post #10 of 24 Old 01-01-2014, 01:37 PM Thread Starter
Thanks guys for the responses. Yea, not quite cold enough in AL to gel the fuel...does not matter what the temp...summer or winter still wants to die.
Don't believe it a traction problem. Sounds like and feels like the engine just wants to "cut off"...lack of fuel or turbo issues? Kind a like the old gas engines when they would spit and sputter due to lack of gas or timing issue, except the truck really don't sputter as bad as the engine seems to want to die. Weird.
Thanks guys I really appreciate all of the feedback.
2012 Raptor 410LEV
The Following User Says Thank You to Ford_Highroller For This Useful Post:
wst625hp (06-25-2014)
