Fuel milage drops after 7k miles. went from 17 to 12 and won't pick up - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 4 Old 11-08-2013, 06:00 AM Thread Starter
Bought the truck new and up to 7k miles and the truck was getting 16.5-17 mpg. After 7k the fuel milage went to 12-13 and won't pick back up. Been to tje dealer 2 times now and no problems but still bad milage I have 37k on the truck. At 21k I did a dpf delete and a tuner on tje truck and it did not help some times at an idle the truck has a rough idle and sounds like it is under a load miss or heavy load on it. Not the type writer sound that is normal. Cant explain. Please help.
bastropdriller2 is offline
post #2 of 4 Old 11-14-2013, 08:27 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
I would change your tune and see if that helps and if you have bigger than normal tires recal you speedo so you MPG guesser thing works better
Carli'd6.7 is offline
post #3 of 4 Old 11-14-2013, 08:32 PM
Carli'd6.7's Avatar
I run a modified version of the SPE HotX off an HS XRT and the truck runs like a dream and idles all day if ya wanna try it PM me
post #4 of 4 Old 11-14-2013, 08:44 PM Thread Starter
I would like to do something. I run the spartan tuner and have tried all the tunes. I had dropped before I had ever touched the stock truck. My name is David 512-845-6618
