2011 6.7 blown - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 14 Old 09-16-2013, 09:51 AM Thread Starter
2011 6.7 blown
I have been lurking on these forums for a while, and thinking 'glad it's not my truck'. Well, I'm here to say that last night I blew my 6.7. It has 36,600 easy miles on it, and it's 100% stock.
On my way home last night towing an empty 900 pound small trailer, merging onto the highway with moderate to heavy (but not full) throttle, I hear a ticking develop - Like a valve out of adjustment. I slow down, and the sound escalates into a loud rap and I lose some power. Limp off the next exit and shut down. Oil leaking from under the truck and sprayed all over everything.
If I had a guess, something in the valve train let go and caused an interference in one of the cylinders, which caused a rod or piston to break. I am not sure where the oil is leaking from, but assuming there is a hole punched somewhere. What a nightmare.
It had a new radiator at 18K. Two weeks ago I blew two injectors out of the head on cyl #4 and 5. Ford fixed, and also changed the oil and filter as well as both fuel filters 500 miles ago. Ford roadside towed the truck to Metro Ford this morning. I am waiting on an update, but guessing a new motor is in my future.
I would have to think that a regional service manager - if there is such a person, would want to come take a look at this motor. If I were Ford, I'd be very interested. It's not a Chassis Cab - it's a Crew Cab. I have read about the issues with the detuned versions in the 450/550.
I have not seen many of you on these forums with this type of major failure on this motor.
I have to say I'm a bit upset about spending 60K for a truck and having these problems. I hope Ford stands by this truck.
It's an F350 with a January 2011 build date.
Here is a quick video clip of the truck running when I pulled off the road: 2011 Ford F350 with blown 6.7 Power Stroke Diesel - YouTube
aquasport17 is offline
post #2 of 14 Old 09-16-2013, 10:16 AM
holy jesus that sounds like crap....I hope they do cover that and should
" The CB Hooker"
2012 F250 SRW 6.7l Scorpion Powered
Powerstrokin7.3L83 is offline
post #3 of 14 Old 09-16-2013, 10:22 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
keep us posted im interested as well
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 14 Old 09-16-2013, 10:43 AM Thread Starter
Yeah, note the oil covered undercarriage and puddle of oil on the pavement. What a mess. I'm currently waiting for an available tech to look at it, but doesn't look like it will get in the bay today.
On a side note, Metro Ford claims the injector clip replacement work which was done two weeks ago under warranty at a different Ford dealer, doesn't show up in the computer. I had to have them fax it, which was a painful process in itself.
I'll certainly be keeping this thread updated with new info as I have it.
post #5 of 14 Old 09-16-2013, 11:03 AM
Sub'd for updates
Moto2four is offline
post #6 of 14 Old 09-17-2013, 12:44 PM Thread Starter
Wink Update
According to my wishy-washy service adviser, Ford has authorized a long block replacement which has been ordered, and should arrive Thursday.
When I asked him what happened to the motor, he referenced the recent injector clip replacement, and said "when the injector blew out it bent something." Now, I find this hard to believe for many reasons - namely the fact that immediately after the injector clips were replaced - and I mean IMMEDIATELY - I drove the truck 800 miles from MA to NC towing a small trailer with no problems at all, and then came back another 800 miles. It wasn't until the last 100 miles of the trip that it let go. Keep in mind that all 8 injectors are perfectly fine in that video link above. There is no smell of diesel, and no compression sound like there was when the injector came out two weeks earlier. Only oil all over the place.
Maybe I am crazy - but tell me what about an injector coming out of the head would eventually (1500 mile later) lead to what sounds like a broken rod, piston, valve? Broken enough to send something through the block and spew oil.
The other thing I don't get - a lot of us here are gear heads - at least to an extent. A guy like me wants to know a little bit more than the average person when it comes to things like this. I know the tech isn't making any money if he's on the phone explaining to me what happened, but it would certainly be nice to chat with him quick and get some answers.
Honestly, the more I think about it, I am not even sure the tech knows. It sounded to me like they took a look, told the Ford rep what it sounded like, and that there was oil leaking, and Ford said yep, order a long block. And instead of the tech tearing down the motor, he just pulls and replaces and someone else figures out what happened.
Someone at Ford wants to know what happened right? I know they keep this stuff hush hush, but I wanna talk to the guy who knows what happened to it. It EATS me not to know. Maybe I will be lucky and one of you guys was the tech working on it
Anyone know what the process is for things like this? Does a regional tech/engineer come out and take a look? Or does this motor just head back to the scrap bench to be rebuilt without any analysis? Also, maybe someone can tell me if I am getting a re-manufactured motor, or a new one.
This is a motor that was perfectly maintained from the start, never driven over 75 mph for more than a minute, and never towed more than a few thousand pounds every once in a blue moon.
Ok, end of rant. Will update as I have new info.
Oh - the adviser claims I don't get a rental car unless I have ESP. I call BS. He's escalating it to someone to try and get me a rental.
Jeff
post #7 of 14 Old 09-17-2013, 12:53 PM
ngaraiderman's Avatar
Jeff
Reman hell! 60K and it only has 36k miles on it. I would demand a brand new one. That's some Bullchit! And if they were any kind of a dealer they wouldnt even think twice about giving you a car.
ngaraiderman is offline
post #8 of 14 Old 09-17-2013, 01:03 PM Thread Starter
Well, I don't THINK I'm getting a re-manufactured motor. But who knows. Maybe someone here does. I thought I read on the forums someplace that Ford does NOT use remans for these replacements.
I'd also like to know if the motor will have the updates and enhancements that the current production motors have. Is there a way to tell a year on it?
I'm certainly curious what happens with the mileage, engine hours, etc. I would guess the miles stay the same. Can the hours be reset?
If I thought Ford would buy it back I would ask - I am pretty sure that would be a long battle.
My decisions are now focused on my next move: Trade it for a 13 or 14, trade it for a competitive brand, or drive it until the 5/100 is up.
post #9 of 14 Old 09-17-2013, 03:17 PM
the valve failures were not limited to the c&C trucks. pickups had the same sub-par components, just typically lighter duty cycle so it takes a little longer to show up. Without actually seeing the engine, I would bet $2.00 it started with an exhaust valve failure.
poormanscat is offline
post #10 of 14 Old 09-17-2013, 03:25 PM
<<---"Shadow"---
sea71's Avatar
My truck did exactly what yours did 2 months ago. Same sound, same chain of events in the last few seconds. Ford said tear down, and tech found where valve dropped and piston was hit. They sent NEW long block and installed. That was 2500 miles ago. Just dropped factory oil out today and changed filter. For what its worth, my old engine sat in crate at dealer for a month. My friend in parts said Ford didnt want it back, that it was up to the dealer to do whatever. Didnt quite understand that part, but it wasnt my business.
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
