P0087 Fuel rail pressure low limp under acceleration - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
 2Likes
post #1 of 15 Old 08-21-2013, 10:59 AM Thread Starter
donniesd's Avatar
Guys,
Getting the P0087 - Fuel Rail Pressure Too Low.
It happens under heavy acceleration.(Like being on the on-ramp of the freeway). if i keep a light foot. Code never comes up. Went a week no problems.
Any ideas on what causes this. Truck as been at dealer for 3 days now. They are still diagnosing. They even went ahead and changed the filter again and still getting the code.
The dealer is reputable and even has its own diesel department. So i don't think they are clueless.
Truck has 50k Miles. Fuel filter changed at dealer every 10k miles. Only use good diesel at places with a big turn over rate.
donniesd is offline
post #2 of 15 Old 05-21-2015, 05:54 AM
P0078/low engine power
I have exact same problem with my 14 6.7. It is in dealer shop right now for 4th time. Last time they changed the pump in the tank, still same problem occurred. They are looking at the sensor that reports this condition and the computer that reads it.
will post if they get it fixed
cliff918 is offline
post #3 of 15 Old 05-21-2015, 01:59 PM
Dealer called back on truck.
Ford recommends complete fuel system replace to cure problem 18 hr job, fortunately it is still under factory warranty.
cliff918 is offline
post #4 of 15 Old 05-21-2015, 02:12 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 385 Post(s)
You have no idea how lucky you are... Usually Ford screws people when the hpfp needs to be replaced. I hope for your sake they don't find rust and send pics/parts to Ford.
drivininidaho likes this.
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, SCT X4 Tuned by Gearhead and RCD, Monitored by CTS
-Matthew
CrazyS0b is offline
post #5 of 15 Old 05-22-2015, 04:02 AM
They said they checked for that and found no rust or contamination. Truck only has 24k on it should have no rust at that age.
cliff918 is offline
post #6 of 15 Old 05-22-2015, 08:57 PM
BigGreen06's Avatar
Quoted: 105 Post(s)
How often have you changed your fuel filters?
Had this happen on my 2010, didn'ttchange the filters for 20k, so the HPFP pretty much died. Truck was just out of warranty and $850 later for a new fuel pump it was fine.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #7 of 15 Old 05-23-2015, 05:19 AM
Filters changed every 10k and water sep drained monthly, have never seen any water in what was drained. Dealer said everything is clean and it will be covered on warranty.
cliff918 is offline
post #8 of 15 Old 05-27-2015, 07:06 PM
For some reason the HPFP will start making metal somewhere between 30000 and 50000 miles. It will send tiny particles of metal from the gears forward through the fuel system causing that code. Ford will try to blame it on not changing the fuel filters or not using, "quality fuel". But when there is metal forward of the pump and none from the tank to the pump that is a clue. You should make sure and pressure the tech. to look further if they try to blow you off. It has been my experience they will take the easy way out every time. The protocol for that code is to check the filters. If the filter has discoloration that is where they stop. They will tell you about the filter, replace it then run the engine. If the code does not promptly come back that is where they stop. They will send you on your way. The pump is slowly coming apart in the meantime.
wardtp is offline
post #9 of 15 Old 05-28-2015, 03:57 AM
Thanks for all the info on the HPFP.
I am picking up the truck from the dealer today. Was told that Ford now has a kit for this problem it replaces every part in the fuel system including injectors all the way back to the tank pump. I think they are shotgunning the problem, but if Ford has developed a specific kit for this issue then there are many more out there that have this problem or will have it. My truck only has 24K on it.
cliff918 is offline
post #10 of 15 Old 05-28-2015, 05:54 AM
Quoted: 247 Post(s)
Ford developed a kit for simplicity. Dealer orders 1 part number and gets what is needed instead of 15 separate parts.
It is not some magical fix, just an oem replacement kit with all parts needed.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
