Red diesel fuel - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 4 Old 08-10-2013, 08:10 AM Thread Starter
Red diesel fuel
Hey guys just wanted to double check, but my understanding is red fuel (off-road/non-taxed) is just fuel that is colored red from a dye. It has no harmful/different effects than regular diesel correct?
Also anyone recommend any aftermarket fuel filter/bypass kits? I've heats Amsoil makes one... ?
Sent from AutoGuide.com App
kaiguy702 is offline
post #2 of 4 Old 08-10-2013, 08:18 AM
08powerstroke6.4's Avatar
Quoted: 33 Post(s)
Same diesel just got dye in it
Chris
2012 f350 crew cab dually lariat
h&s tuner w/dpf delete
5in exhaust w/fte resonator
2008 f250 reg cab short bed
Livewire w/tyrant tunes
Dual exhaust
Already faster than my 6.0 :/
2006 f250 crew cab king ranch
Head studs
Mpd 175/30 inj.
Fass fuel pump w/sump
4in mbrp exhaust
s&b intake
ec-1 coolant w/coolant filter
blue spring upgrade
powermax turbo w/ billet wheel
egr delete
sct livewire ts w/ php tunes
Atlas 40 ficm
08powerstroke6.4 is offline
post #3 of 4 Old 08-10-2013, 08:29 AM
chancelor's Avatar
i burn over 600 gallons of red fuel a day at work in 3508 Cat engines, in 399 Cat engines, in fork lifts in man lifts and it never causes a problem anywhere, everyone will try to tell you it wont run in this engine or that engine they are wrong. It has dye in it. thats it. I have had times where i was on location and low on fuel and have put it in whatever i was driving from my 2012 6.7 ford my 2006 6.0 ford and all of my dodges. as long as it is filtered i have never had a problem with it.
2006 F350 4X4 Lariat... Just getting started with this one... afe air intake, edge juice platinum with attitude, coolant filter kit, high idle switch added, blue spring conversion Fan clutch switch, daystar leveling kit, zoodad, a few extra lights, custom gooseneck hitch and air bags on the rear
chancelor is offline
post #4 of 4 Old 08-14-2013, 05:49 AM
2013F250Tank's Avatar
Just dye but your wallet will take a beating if they find it in a on road vehicle.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
