tip for anybody getting turbo warranty work - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 31 Old 08-09-2013, 08:46 AM Thread Starter
08powerstroke6.4's Avatar
Quoted: 30 Post(s)
Before you take ur truck in to get the turbo replaced under warranty which is a matter of when not if, change the air filter! There using that as an excuse not to cover my turbo that only has 10k miles on it. Thought everyone should know
Chris
2012 f350 crew cab dually lariat
h&s tuner w/dpf delete
5in exhaust w/aeroturbine muffler
2008 f250 reg cab short bed
Livewire w/gearhead tunes
Dual exhaust
Already fast as my 6.0 :/
2006 f250 crew cab king ranch
Head studs
Mpd 175/30 inj.
Fass fuel pump w/sump
4in mbrp exhaust
s&b intake
ec-1 coolant w/coolant filter
blue spring upgrade
powermax turbo w/ billet wheel
egr delete
sct livewire ts w/ gearhead tunes
Atlas 40 ficm
08powerstroke6.4 is offline
post #2 of 31 Old 08-09-2013, 09:11 AM Thread Starter
Quoted: 30 Post(s)
What gets me is they said the filter was dirty as they ever seen but the little gauge that sucks in when the filter is plugged wasn't sucked in all the way. It was in some but not in the red. Correct me if I'm wrong but I don't feel this bill should be on me!
Chris
Dual exhaust
Head studs
Mpd 175/30 inj.
4in mbrp exhaust
s&b intake
blue spring upgrade
egr delete
Atlas 40 ficm
post #3 of 31 Old 08-09-2013, 10:26 AM
I_AM_RP3's Avatar
If you are within the regulations of the manual, meaning that it wasn't time to replace it or it didn't say to then no, that bill should not be on you. Make sure you take a picture of the filter and the indicator to have for your records and then raise some H-E-LL. I would call ford too.
I_AM_RP3 is offline
post #4 of 31 Old 08-09-2013, 10:41 AM
c69ss396's Avatar
be sure and call fords customer care number also..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 31 Old 08-09-2013, 12:17 PM Thread Starter
Quoted: 30 Post(s)
I'm going to see what I can do. I'm afraid if I say to much they will just bring up its dog deleted and get out of it that way. The service guy said they already condimed the truck what does that mean? I wonder if I can replace the air filter and take it somewhere else?
Chris
Dual exhaust
Head studs
Mpd 175/30 inj.
4in mbrp exhaust
s&b intake
blue spring upgrade
egr delete
Atlas 40 ficm
post #6 of 31 Old 08-09-2013, 12:48 PM Thread Starter
Quoted: 30 Post(s)
Dpf deleted*
Chris
Dual exhaust
Head studs
Mpd 175/30 inj.
4in mbrp exhaust
s&b intake
blue spring upgrade
egr delete
Atlas 40 ficm
post #7 of 31 Old 08-09-2013, 12:53 PM
I_AM_RP3's Avatar
I'm pretty sure condemned it means they marked it in the system as warranty being denied or void. If so then taking it to another dealer won't work unless you find a more "friendly" dealer. And with it being deleted that might not happen.
I_AM_RP3 is offline
post #8 of 31 Old 08-09-2013, 02:59 PM Thread Starter
Quoted: 30 Post(s)
The dealer its at didn't care that it was deleted they said as long as it didn't cause the problem no worries. They warrantied the last turbo with no problems 10k miles ago
Chris
Dual exhaust
Head studs
Mpd 175/30 inj.
4in mbrp exhaust
s&b intake
blue spring upgrade
egr delete
Atlas 40 ficm
post #9 of 31 Old 08-09-2013, 03:09 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Id be beyond pissed off
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 31 Old 08-09-2013, 08:23 PM
are you running any aftermarket programming/tuning? Are you running an aftermarket air filtration system?
poormanscat is offline
