Air Filter Dummy Gauge - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 4 Old 04-21-2013, 04:21 AM Thread Starter
USMC(Ret)
fishman's Avatar
Quoted: 3 Post(s)
Garage
Does it work? I've got about 30k on the motor and the original air filter and the gauge has never even budged. I pulled the gauge and ran a vacuum check and it is operating correctly. Could there be a leak in the air box causing no vacuum to register or should I believe that after 30k, the filter is "good as new"?
2011 F-350 CrewCab FX4 Lariat LWB
20" stock wheels, Michelin 34" ATs, E3.55 gears
aFe Stage 2, Diamond Eye DP back w/ muffler, HSM intercooler pipe, Rudy's EGR plates, SCT X4 w/ GH tunes
LINE-X, X-Stang Solid Fold
Traded:
2005 F-250 CrewCab 4X4 XL SWB
fishman is offline
post #2 of 4 Old 04-21-2013, 04:31 PM
More than likely, its fine... My 2011C&C truck never moves the filter restriction gauge either...
FWIW, the filter minder on my 06 Dodge will pull in to the red every time I get above 30 psi of boost.... Even with a brand new filter installed.
poormanscat is offline
post #3 of 4 Old 04-23-2013, 01:28 AM Thread Starter
USMC(Ret)
fishman's Avatar
Quoted: 3 Post(s)
Garage
thanks poormanscat.
any idea how long these filters should last? i guess because of the gauge, they don't list them in the maintenance schedule.
Traded:
fishman is offline
post #4 of 4 Old 04-24-2013, 05:54 PM
Im sure you will get many opinions on this matter, but IMHO, an air filter is ok up to the point where it restricts enough airflow to cause power loss or fuel mileage drop... filter actually filter better when dirty vs clean..
If you are only driving on highway, theres no telling how long your filter can actually go..
