Truck not starting??? - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 4 Old 04-15-2013, 02:15 PM Thread Starter
Got a 12 6.7l that we are currently rebuilding and about got it done but it is not firing up. All it does is crank over. There should be no reason for it not to start...checked all the fuses etc. Also noticed when I turn the key it will keep cranking over unless I turn the key back...seems strange to me. Am use to the duramax so am trying to figure this thing out.
Thanks and sure would appreciate your help, Jonathan
windowbarn is offline
post #2 of 4 Old 04-15-2013, 02:25 PM Thread Starter
Nevermind...hit the fuel reset button and it fired right up!!! relief
post #3 of 4 Old 04-16-2013, 08:15 AM
Where is the fuel reset button located?
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #4 of 4 Old 04-18-2013, 01:34 PM Thread Starter
It's on the passenger side of the dash, you can see the access panel when you open the door.
