EGR cooler ??? - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 14 Old 02-25-2013, 03:33 PM Thread Starter
EGR cooler ???
I work for the public works dept and we got 2012 1 ton dump in the summer. It has 4100 on it and just had to have an EGR cooler put on it. It does idle a lot. It has something like 400 and some engine hrs on it and half on them are idle hrs. Sounds like this will keep happening. They told me to drive it harder to clean it out. So my question is would the delete be a better option? Hard thing would be talking my boss into doing it.
01 CCSB 7.3 4X4
4 in Lift
37x13.50 Toyo MT on XD Hoss
TS Chip
ISSPRO Gauges
Straight Piped
DIY Intake
Overboost Annihilator
Wicked Wheel
01whitey24 is offline
post #2 of 14 Old 03-03-2013, 09:15 AM
mpichner's Avatar
Not a hundred percent sure on this but if you do the egr delete im thinking you would have to delete the dpf as well , seeing that the egr system aids in raising exhaust temps for regens????
11 F350 6.7 Lariat ultimate cc short, HS Mini Maxx, 5" Flo-pro, 3" rough country lift, lock picked, gooseneck hitch, air lift bags, recon strobes (tow rig/ toy)
06 Jetta TDI, Malone tuning +30hp, egr/ shutter valve delete (work comuter)
05 F250 6.0 Lariat cc short, Banks Big Hoss bundle, gooseneck, leveling kit, black moto 951s, (SOLD)
99.5 F250 7.3 cc short, 8" skyjacker, traction bars, Banks powerpack system stacked with 6 gun, (SOLD)
mpichner is offline
post #3 of 14 Old 03-03-2013, 01:24 PM
BIG Laing's Avatar
Fail all over ^^^. You can do an EGR delete (federal offense if registered for public roads) but you need a tuner ( about $1000). Most people that have already spent the money on the tuner will delete the DPF (a 2nd federal offense) also.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 14 Old 03-03-2013, 01:37 PM
mpichner's Avatar
Re: EGR cooler ???
Never said it was legal!!!!
mpichner is offline
post #5 of 14 Old 03-03-2013, 04:51 PM
BIG Laing's Avatar
Everything here ^^^ is wrong. Well I guess the part about you being "not sure" was right.
I never said that you said it was legal. I was letting the OP know it is illegal.
post #6 of 14 Old 03-03-2013, 05:58 PM
mpichner's Avatar
Re: EGR cooler ???
OK fine did some reading. Egr systems are designed to cool the combustion chamber to create less NoX. My findings after deleting the erg system on my 6.0 was 100-150 degree cooler egts (in the manifold) at highway speeds. Besides that can you do an egr delete without dpf delete? I've always thought the dpf needs the egr system???
mpichner is offline
post #7 of 14 Old 03-04-2013, 01:57 AM
BIG Laing's Avatar
The DPF would soot up to the limit faster without the EGR. So regens would be more frequent. They are independent of each other though. And if for some weird reason you wanted to keep one and not the other, you could.
The DPF has two types of regens active and passive. passive are triggered when EGT are 572* F and above, so an EGR could help get you to this, but that's not really a good thing in my mind. Active regens are the ones you see the msg for, when your MPG drops for 15 mins. Raw fuel is being sent down the exhaust while the EGR valve is closed.
But to get rid of either one you need a tuner. And if your going to spend $1000 (minimum, can be closer to $1500 now) there is no reason to not spend the extra $50 for an EGR plate, and $100 for the DPF delete pipe (or $400 DP back).
post #8 of 14 Old 03-06-2013, 11:35 AM
brstanle's Avatar
Quoted: 2 Post(s)
In my opinion, it is not wise to break federal laws with a vehicle that's not your own. Especially with a publicly owned vehicle. It just seems like a very, very bad idea.
brstanle is offline
post #9 of 14 Old 03-06-2013, 11:52 AM
Quoted: 18 Post(s)
I'm not sure about this. The EGR deals with NOx not Soot. The EGR reduce the combustion temperature in the combustion chamber? This has the effect of reducing the NOx that is produced at high combustion temps. This is why our trucks have a smaller EGR than previous generation engines. because it deals with the NOx in the SCR by injecting DEF to reduce the NOx.
The DPF is the component that deals with the Soot. It has a filter that collects the soot and then burns it into ash during the regen process. Each part of the emission system addresses a different pollutant. Soot vs NOx.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
post #10 of 14 Old 03-06-2013, 09:40 PM
BIG Laing's Avatar
The EGR puts the soot (and all exhaust) back in the cylinders right? I thought it helps burn soot/unburned fuel...
