6.7 died and won't start! - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 51 Old 10-10-2012, 10:45 AM Thread Starter
brdgraf's Avatar
Was running great and started making a real quiet sputtering or rattling sound then engine light comes on and says reduced engine power. Will turn over but won't start. Any ideas? Only mod is AFE intake
2012 F-250 6.7L Lariat CC White platinum and pale adobe two tone
AFE Pro dry intake
Recon smoked cab running lights w/ amber LED's
Recon smoked mirror side lenses w/ amber LED's
brdgraf is offline
post #2 of 51 Old 10-10-2012, 02:32 PM
did you get a message for low fuel supply pressure on your display?.. I would remove the AFE and put it back to stock before sending it to the shop....
poormanscat is offline
post #3 of 51 Old 10-10-2012, 03:52 PM Thread Starter
brdgraf's Avatar
No all it said was reduced engine power. It was making some sputtering sounds from under hood but I could barely hear anything really. Yeah I was gonna take it straight to dealer but decided to wait and take AFE off first. Don't think it contributed any to the problem just don't want to give them any reason not to warranty it. I sure hope its something simple and not engine failure
AFE Pro dry intake
brdgraf is offline
post #4 of 51 Old 10-10-2012, 04:49 PM
Hmm
Keep us posted
Boat Hauler is offline
post #5 of 51 Old 10-10-2012, 05:11 PM Thread Starter
brdgraf's Avatar
Will do
AFE Pro dry intake
brdgraf is offline
post #6 of 51 Old 10-10-2012, 05:17 PM
powerstroke4713's Avatar
Did you see any fuel leaking anywhere? I know the injector hold downs break and there is a TSB for it. Make sure it is back to stock so they have nothing to denine your warranty!!!! If they have an out they will stick it to you if they can.
powerstroke4713 is offline
post #7 of 51 Old 10-10-2012, 05:19 PM
will it generate any boost at all? CEL?
post #8 of 51 Old 10-10-2012, 05:24 PM
PowerStrokin6.7's Avatar
My afe intake just came in and there is a paper inside that says there has been problems with it in the 2011 powerstroke 6.7 and that and engine light will come on blahh blahh.. it says to see the ford dealer for the fix because it happens in some trucks with the stock exhaust also.
BIG DOM
PowerStrokin6.7 is offline
post #9 of 51 Old 10-10-2012, 05:28 PM
KAKnight's Avatar
Good luck ombré
- Bubba
KAKnight is offline
post #10 of 51 Old 10-11-2012, 10:08 AM Thread Starter
brdgraf's Avatar
No didn't see any fluid leaking anywhere. It always boosted around 20 when u got on it hard and was running great and this just happened all of sudden. Had intake on for 2500 miles no probs. thanks guys for input
AFE Pro dry intake
brdgraf is offline
