throttle sticking - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 6 Old 08-14-2012, 01:49 PM Thread Starter
throttle sticking
My father has a 2008 6.4 with just under 40K. He says the other day that while rolling through a parking lot the engine began racing without his foot on the pedal. He was able to stop and shut the engine off. When he started it again, it was fine. Anyone else experience this??
spap is offline
post #2 of 6 Old 08-14-2012, 01:52 PM
mazsecond's Avatar
Feedback Score: 4 reviews
You mean 6.4 not 6.7, the 6.7 wasn't offered until 2011. I don't know much about the 6.4/6.7, I'm a 6.0 guy but I just saw this and thought I would clarify that. Hopefully someone will come along and help you out.
Heres a free
Mike
mazsecond is offline
post #3 of 6 Old 12-10-2013, 03:37 PM
ars5147's Avatar
Quoted: 116 Post(s)
Thread revival. This just happened to me. Coasting off the interstate on the offramp the truck floored itself and went almost to 4,000 rpm. Stood on the brake to avoid smashing anyone and shifted to neutral. Hit reverse but I was almost stopped at that point. Made a bang noise but everything tranny wise seems to be fine.
I was not touching pedal, pedal was not stuck on floor mat. Just went nuts on its own.
Scary as heck
Any thoughts?
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #4 of 6 Old 12-13-2013, 07:54 AM
WoodBoy's Avatar
Scary as heck
Any thoughts?
Drove it since? Checked your oil level to make sure it isn't full of fuel?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 6 Old 12-14-2013, 03:13 AM
ars5147's Avatar
Quoted: 116 Post(s)
Ya drove it about 600 miles since. Oil has not fuel from what I can tell.
I believe it sucked in some oil hanging out in the intercooler and piping. The oil is a little over full but thats from me. It was only a quart though. Always just dump 4 gallons of T6 in it instead of measuring out 15 qts. Have been doing it this way for the last 38,000 miles.
I just put on my mishimoto intercooler and cold side pipe and found a good bit of oil in the old cold side pipe. I will be rigging up a CCV delete here soon to keep oil out of my nice new intercooler.
A little extra oil over that many miles and the blow by of a 6.4 might have been it. I will keep a closer eye on stuff and see.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
ars5147 is offline
post #6 of 6 Old 12-14-2013, 03:19 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Probably should start your own thread since this one is in the wrong section... Or get it moved to the right spot.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
