low oil pressure lite - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 11 Old 05-14-2012, 07:13 AM Thread Starter
so i'm driving along empty, get a pull over as soon as possible warning, so i do and the engine shuts down, warning lite says low oil pressure....wtf...so i get out and check the dipstick, oil is full....get back in, truck won't start...hitch into town, no cell coverage where truck quit....get tow truck, back to my truck, turn on key, no idiot lite/warning, so i start it to get it to line up with tow truck bed, works fine....take it to dealer...waiting to see what they say.....any body with experience with this?....
slyrydr is offline
post #2 of 11 Old 05-14-2012, 02:16 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 11 Old 05-14-2012, 03:43 PM Thread Starter
the dealer discovered the problem....the nox sensor in the exhaust had a short in it which automatically shut down the engine, resulting in the low oil pressure lite being illuminated, as well as the check engine lite and a couple of others....when the incident happened, the "voice" said to pull over to the side of the road as soon as possible, safely, of course...as i did so, trying not to get into the snow too deeply, the engine automatically shut down at about 10 mph, resulting in the low oil pressure lite....as i was concentrating on vehicle management with no power steering, i didn't get my eyes back on the dashboard until i was stopped, then seeing the low oil lite, i assumed that was the cause of the engine shutdown....but it was just the nox sensor, easy fix, no other problems..
slyrydr is offline
post #4 of 11 Old 05-15-2012, 01:52 PM
StonemanQA's Avatar
Just had the recall for the NOX sensor replace/or recall ration done two weeks ago. Talking to the tech it seems some of the sensors did not take to the 400/800 programming and either fail or will fail eventually without the upgraded software. The dealer will replace the sensor if it has triggered any codes 34000mi and no codes so I got a PCM update and a TCM update. Drove like crap for a day until the tranny "relearned" again. Have put 2200 mi since then an no problems.
2011 job2 F-250 XLT CC LWB SRW 4x4
6.7 PS! Awesome engine
Tuxedo Black, Steel interior
E-Locker, 3.55's, sway, stability control
Trailer package, Valley WDH,
18" rims
20 mpg mixed driving empty
14 mpg towing new holland skid loader
39525 mile
S and still ticking!
Traded:
1996 F-350 XLT CC LWB SRW 4x4
7.3, 4.10's
Silver on Black with steel interior
257000 miles
Billet torque converter @ 127000 miles with upgraded
Shift controller
15 mpg downhill with a tail wind empty.
StonemanQA is offline
post #5 of 11 Old 10-14-2012, 02:24 PM
mbbrewton's Avatar
Quoted: 2 Post(s)
I just had this happen to me! Shut down warning, then it shut down. No oil pressure, but crankcase is full. It's sitting at the tow yard currently until Monday. I just had the NOx sensor changed about 3000 miles ago.
mbbrewton is offline
post #6 of 11 Old 10-14-2012, 02:29 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Did it say no oil pressure once the motor quit running?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 11 Old 10-14-2012, 03:59 PM
Thats odd, the C&C trucks do NOT shut down for a NOX sensor failure... nor should they...!!!
NOX sensor failure should only derate engine, NOT shut down. Have had multiple NOX sensor failures on my C&C truck, only derates, does not shutdown.
poormanscat is offline
post #8 of 11 Old 10-14-2012, 04:53 PM
6.0f250firstcar's Avatar
This is why I'm unsure about the new trucks. Don't like the fact they can shut themselves down and just not crank. Even if it is to try and protect the engine.
6.0f250firstcar is offline
post #9 of 11 Old 10-14-2012, 05:12 PM
mbbrewton's Avatar
Quoted: 2 Post(s)
My truck was showing no oil pressure before it shut down. Checked oil and it was full. I have had NOx sensor problems.
post #10 of 11 Old 08-29-2013, 08:12 PM
How was this problem resolved?
PwrStrkNewbie is offline
