TURBO HAS FAILED 19000 MILES - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 74 Old 04-20-2012, 12:58 PM Thread Starter
Well here goes, 2011 f250, mini max w/dpf delete afe cold air intake. Jumped in the truck wednesday to go to store and made it about a mile and the turbo is done..... came around a corner and gave it throttle and nothing so I look at boost gauge and there is 0 boost, look in mirror and just solid smoke!
Going to return truck to stock and trailer it to dealer with the trusty 7.3
What a bummer, Ill keep you posted.
penrosetractor is offline
post #2 of 74 Old 04-21-2012, 02:15 AM
Nissankidd's Avatar
Wow I hate to hear that. Keep us posted.
2015 F-250 platinum
Nissankidd is offline
post #3 of 74 Old 04-21-2012, 02:56 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 74 Old 04-21-2012, 05:53 AM
Are you sure an intercooler hose didnt blow off?
socal2ks is offline
post #5 of 74 Old 04-21-2012, 02:18 PM
why return to stock?
2011 F260 6.7 CC 4x4 LB
gsxr1300 is offline
post #6 of 74 Old 04-27-2012, 09:37 AM
jka74 is offline
post #7 of 74 Old 04-27-2012, 10:25 AM Thread Starter
Returning to stock to try and get it warranty covered ( worth a shot)
Got almost already to go just waiting for a kidney stone to pass so I can finish.
The oil seal is out in the Turbo for sure, had a mess when I removed exaust and I have
checked all tubes and hoses and they are fine......... I do wish there was aftermarket options
so if its not warranty then I would go for it!
post #8 of 74 Old 04-27-2012, 10:34 AM
To try and commit warranty fraud...
Waxy
Waxy is offline
post #9 of 74 Old 04-27-2012, 11:07 AM Thread Starter
Angry
Waxy
Not that I care what you but my dealer knows that the truck has a chip. I had this truck in the dealer with in 30 days of purchase because the Turbo had a terrible lag and was told that it was normal. $70,000 truck buddy I'm sure you would want it covered under warranty if your $2000 Turbo failed at 19,000 miles!
post #10 of 74 Old 04-27-2012, 11:58 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
Tagged
-Julian
4th 6.fo
TwinTurboStroker is offline
