change oil soon message - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 10 Old 03-09-2012, 12:23 PM Thread Starter
buletbob's Avatar
I brought my truck in for the 20000 mile service and had the oil change , I have been using the ford semi synthetic which my dealer said is recommended. well with only 1800 miles since the service, the message center pops up and Say's change oil soon. wtf!.
when you change the oil do you have to reset the message center? I am thinking they forgot to do that. its going in this Monday to have them look at it along with the death wobble that started.would like to get some info before I seek to them and see if they give me a bull sht story so they can bill me. thanks Bob
TRADED
2007 F-350 Supper Duty King Ranch
6.0L Stock
Pioneer LCD Monitors In Head Rests
500 Watt 4 channel JL Audio Amp
250 Watt Mono JL Audio Sub Amp
JL Audio Speakers
10" JL Audio sub Center console
JL Audio Tweaters
Pioneer AVZ1
Custom Pin Striping
Hornet Alarm and remote start.
TRADED HER IN FOR A NEW 2011
NOW HAVE 2011 F-350 DUALLY KING RANCH
6.7L STOCK
GOLDEN BRONZE METALLIC CLEAR COAT WITH THE ADOBE BEIGE TWO TONE BOTTOM
buletbob is offline
post #2 of 10 Old 03-09-2012, 06:17 PM
Yes you have to reset the oil mider in the message center.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #3 of 10 Old 03-09-2012, 06:52 PM
Powerstroke Techie
forddieseldoctor's Avatar
Unfortunately that gets missed way too often. I'm not gonna lie I've missed it before.
As for the death wobble... if it started after your last maintenance appointment I would double check and see what your front tire pressures got set at.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #4 of 10 Old 03-10-2012, 04:13 AM
matty21's Avatar
Sorry to hijack, but what pressures should we be looking for. Mine says in the door 75 front 60 rear and I'm at 80 front and 70 rear and my death wobble is horrible and has been for months . Two alignments, two trackbars, etc etc later it still does it, ALOT.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #5 of 10 Old 03-10-2012, 05:02 AM
Powerstroke Techie
I run whats on the door sticker, but if you're up to max on the tire I don't think it's a tire pressure issue. I was just making the point before that low tire pressures can cause a death wobble. I have only dealt with one truck that had that issue so I'm not gonna claim to be an expert on it.
Meet Double Aught
2000 F250
post #6 of 10 Old 03-10-2012, 03:02 PM Thread Starter
buletbob's Avatar
yes I had to add to the tire pressure wen I picked up the truck from service the truck felt spongy, so I check the pressure and they had it at 50psi front and back. So I inflated them to the door panel spec's . better ride but still have the wobble on slight left hand turns when hitting expansion joints in road. ?I'm going to bring it into ford Monday just to have them look at it and document it. if they cant fix it, I'm going to add the aftermarket kit and get rid of the ball joint set up. My tire dealer said he has a costumer with a brand new 2012 F350 with 1500 miles on it and has the death wobble, they change the trailing arm , checked tire pressure, balanced tires and still cant solve it. he wants me to send him the Webb site of the aftermarket kit.
TRADED
6.0L Stock
JL Audio Speakers
JL Audio Tweaters
Pioneer AVZ1
Custom Pin Striping
6.7L STOCK
buletbob is offline
post #7 of 10 Old 03-11-2012, 07:23 PM
Death wobble on a ford? Thought that only happened on Dodges? Is Ford trying to copy that Cummins performance soooo much that they even got the death wobble right?
Just kidding guys, I just had to! Seriously, I've never heard of a caster shake on Fords, is this something new on the latest super dutys?
1998 Dodge 3500 Cab&Chassis, 12 valve, NV4500, 14' Flatbed
2011 Ford F-350 Lariat Crewcab, 6.7, automatic, 4x4 Traded in FERD on a Dodge!!! Back in the land of reliable diesels!
olypopper is offline
post #8 of 10 Old 03-11-2012, 07:26 PM
kingranch89's Avatar
its been going on for a while in the super duty's
2007 F250 king ranch 6.0 powerstroke
SCT w/ custom tunes from innovative
5" mbrp exhaust
Studded and EGR Deleted
FINALLY SOLD!!!!
on to the next toy
kingranch89 is offline
post #9 of 10 Old 03-11-2012, 07:33 PM
Must be the ONLY reason for independant front suspension huh? I know when it happened on my Megacab it was always the steering stabilizer going bad. I'd guess it's different for each truck. Which sucks for diagnosing the issue.
post #10 of 10 Old 03-12-2012, 03:46 PM Thread Starter
buletbob's Avatar
here is the follow up with the service appointment. they changed the steering Damper which there was a TSB for. and check tire pressure, all seems fine so far, the steering seams to feel tighter, as for te message center displaying change oil after 2300 miles the service mach. forgot to reset it. all is fine . Bob
TRADED
6.0L Stock
JL Audio Speakers
JL Audio Tweaters
Pioneer AVZ1
Custom Pin Striping
6.7L STOCK
buletbob is offline
