6.7 Turbo surging. - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 12 Old 11-12-2011, 12:01 PM Thread Starter
markab71's Avatar
6.7 Turbo surging.
I have a 2011 F250 with the 6.7 in it. When I set the cruise control the turbo will surge from 10 pounds of boost to 0 pounds of boost, then it will level itself off...I don't know if it has been doing it all along and I just noticed it or if it just started doing it. I would greatly appreciate it if some of ya'll could keep you eye on your boost gauge. It ONLY does it with the cruise set, No bogging down or hesitation what so ever.
markab71 is offline
post #2 of 12 Old 11-14-2011, 08:22 PM
Mine does it too. I've brought it up on the forum before and its not real uncommon. Mine will do it for the first few miles after i set the cruise then smooth out and work fine.
cthaeffner is offline
post #3 of 12 Old 11-15-2011, 05:20 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
No issues here.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 12 Old 11-15-2011, 06:18 PM
Anth's Avatar
Mine also does the surging, I pulled a dump trailer around today some. After I unhooked the trailer and started driving it again and set the cruise it was pretty surge. But after a few miles it all went back to normal, I also have a afe on intake on my truck. I don't really think it's anything to worry about.
2013 Platinum White, Dura Flaps, B&W turnover,
mpd s365 turbo kit, tuned by craig at mpd, no limit egr delete, amp steps, icon leveling kit, ouo traction bars, 20x10 bmf wheels, 35 toyo mt, bushwacker fender flares, painted to match headlights with projectors, absolute performance ccv kit.
Anth is offline
post #5 of 12 Old 11-15-2011, 07:36 PM
Hawkeye Diesel's Avatar
I've noticed mine does this as well, usually for 3 or 4 miles at highway speeds with the cruise set. But, when I watch my mini maxx display, there is no variance in boost, as it stays steady at 4 psi..... so, I wonder which gauge is right, the dash gauge, or my mini readout??
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #6 of 12 Old 11-15-2011, 08:13 PM
I've never watched the boost on the mini maxx when it does it, but the boost levels and defenitly moving. Mine rocks you back and forth in the seat when its surging.
post #7 of 12 Old 11-16-2011, 07:07 AM Thread Starter
markab71's Avatar
Mine does the same thing. Thats what made me notice it, My head rocking everytime the turbo spooled up. My wife works in the service department at the nations 2nd largest Super Duty dealer so I get treated better than most when I go in for service and what not. I brought it in for the surging so she got a tech to go ride with me with the lap top hooked up and of course I COULDN'T GET IT TO DO IT!!! But he did say he didn't think it was detrimental to the turbo, more of a nuisance.
markab71 is offline
post #8 of 12 Old 11-20-2011, 07:30 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Mine does it as well, it drives me crazy. I have seen my 6.7 do it for 15-20 mins on flat ground with the cruise set just to see how long it would actually keep surging. Mine usually stops surging when I start climbing a hill. Now soon as it starts surging, I kick the cruise off for a couple mins then reset the cruise. Seem to fix it .
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #9 of 12 Old 11-27-2011, 01:15 PM
Another guy here with the same deal. Drives me nuts, My dealer doesn't know what to do about it.
2011 ccsb 6.7 Lariat tuxedo black
2006 exlb LLY dmax
Its got some stuff
scorpion is offline
post #10 of 12 Old 11-27-2011, 01:43 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
Mine also surges.. Ford is aware of the issue and will replace your turbo to fix the surge. I was told yesterday by a reputable Ford tech that elevation plays a role in the surge. I dont know where you are all at, but I live at about 4500 ft. and mine surges real bad. He also mentioned that he thinks there has been a redesign within the turbo that eliminates this issue. Take it in for a fix or leave it, its up to you.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
Tags
6.7 , 6.7 turbo , 6.7 turbo problems , turbocharger
