Defective "waste gate solinoid" - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 9 Old 10-19-2011, 10:02 PM Thread Starter
So I noticed a while back, a few seconds after I turn my truck off I get a LOUD buzz coming from the engine bay which gradually tappers off into a faint buzz before going away.
Took it to Ford and apparently Ford Motor Co HAS heard of the issue and is working on a resolve. But for now, nothing they can do. They were supposed to get back to me by now, but haven't.
I have now noticed a faint buzz while the motor is running also.
FYI the truck is bone stock as far as performance mods go. No intake, tuner, or DPF delete.
They say it's not harmful and not to worry in the mean time.
Anyone else get this?
2011 F250 CC SB Lariate
2008 Corvette Z06 590 RWHP 529 RWTQ NA
1993 MR2 700+ RWHP (parting out)
2013 Volkswagen GLI
2015 Jeep Grand Cherokee Overland Diesel
JsnMR2 is offline
post #2 of 9 Old 10-20-2011, 03:36 PM
matty21's Avatar
are you sure its the wastegate solenoid? becuase mine is disconected and i have that noise because i believe its the VCV (volume control valve) . that 29000 psi has to go somewhere when you shut it off
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 9 Old 10-20-2011, 05:10 PM Thread Starter
I'm just goin off what the dealership told me. I'll run it by them.
2013 Volkswagen GLI
JsnMR2 is offline
post #4 of 9 Old 10-20-2011, 05:20 PM
matty21's Avatar
im interested to what they find.
keep us posted
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #5 of 9 Old 10-20-2011, 06:05 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 9 Old 10-22-2011, 01:48 AM
Have you had any sputtering while driving under light consistent load? I just had my turbo replaced (under warranty thankfully) and when the service manager heard the problem during a test ride, he told me it was the waste gate as well. He also told me there was no problem driving the vehicle. I continued to drive the vehicle for about a week while he consulted Ford Engineers. Even after all the directions from the guru's they still kept my truck for 18 days once I took it in for what they told me would be a 2 day fix. 1st they tried a computer reprogram, 2nd they cleaned the EGR, 3rd they cleaned the Mass Air Flow Sensor, finally they replaced the turbo. The only reason they are telling you to keep the truck is to avoid having to pay for you to have a rental car. Also they only have 30 days to fix it under the Lemon Law, so they don't want it sitting around the shop while they scratch their heads.
M308P is offline
post #7 of 9 Old 10-22-2011, 10:34 AM Thread Starter
No sputtering while driving (or ever) at all. A turbo itself would not buzz if something was wrong with it. I doubt they are telling me to keep my truck due to wanting to avoid paying for a rental. I have had my truck in for other warranty work and they have given me a rental without a problem. Also, they said they had to wait on Ford to tell them what to do.
Not only did they give me a rental, but I could not make it in the day it was finished and asked if I could keep it another day. They had no issues with it. Definitely not just being cheap.
2013 Volkswagen GLI
JsnMR2 is offline
post #8 of 9 Old 01-09-2014, 07:12 PM
happystroker's Avatar
did they ever fix the problem my truck is doing the same thing buzzing while idling
2012 ccsb XL Fx4 oxford white
5in MBRP straight pipe
H&S mini max
wet okolole seat covers
kenwood ddx719 dvd head unit
weather tech mats
5%tint
happystroker is offline
post #9 of 9 Old 01-09-2014, 11:55 PM Thread Starter
Yes they fixed it. Has not made the sound once since then.
2013 Volkswagen GLI
JsnMR2 is offline
