Backfire-type sound from the intake...? - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 14 Old 10-04-2011, 05:55 PM Thread Starter
Dr.Evil's Avatar
We installed an H&S Mini, DPF Delete and aFe intake last weekend. No problems, went out for some test runs, ran great. Didn't even touch the HOT setting on the tuner. I've put about 125 miles on it since, just cruising around town, no towing or racing. Heading home today, I hear a couple "pops" that sounded like they came from the intake area. I tried to repeat the noise, and it only does it sometimes when letting off the throttle when in boost. It sounds to me like the wastegate is making a strange noise. I got a pretty loud "POP" once, similar sound as when a gas motor backfires through the carb. I put the tuner back to the stock DPF-delete tune, and it was still occurring. I had been running on the MILD mode. Strange thing is, its not every time I let off when its in boost. Only sometimes. Anyway, got it home, pulled the intercooler line, and didn't notice any excess oil. There was some in there, but it was really black and not fresh looking. Has anyone else had this issue, tuned or not? REALLY hoping I didn't break anything serious.
2011 F-250 Lariat Ex LB 6.7
2001 F-250 R.C. LB 7.3
Dr.Evil is offline
post #2 of 14 Old 10-06-2011, 04:59 PM
I was just about to create a thread identical to this. I am getting the EXACT same thing. I'm running H&S Mini, 5" flo pro downpipe back and AFE intake.
I called my local diesel performance shop and they had never heard of this problem and suggested a call to H&S. H&S said they have never heard of this either and suggested to keep running it as usual. Everything is properly installed and the tuner is up to date and functioning perfectly.
Whatever it is it makes me very nervous.
mmars89 is offline
post #3 of 14 Old 10-06-2011, 07:24 PM
There's already a thread regarding this issue, just found it. Looks like a ton of people are experiencing the same thing. Apparently ford is looking into it. Didn't really get any solid answers from reading all the posts. Some guys are saying the latest H&S update fixes the problem but that is the update I have and it still happens.
mmars89 is offline
post #4 of 14 Old 10-06-2011, 07:32 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
heres a dumb question, why would Ford look into this? Once you tune these and Mod aren't you on your own Troubleshooting wise?
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 14 Old 10-06-2011, 07:49 PM
Just going off all the replies in that other thread, looks like this problem happens stock or with mods. It's just more noticeable with intake since the noise is less muffled.
My knowledge is limited when it comes to this stuff and I found it extremely painful reading through all the arguing in the other thread. I would just like to know if anyone has found a remedy to this issue. Like i said, the best answer I have found so far is "Ford is aware of the problem and is looking into it".
mmars89 is offline
post #6 of 14 Old 10-06-2011, 07:49 PM
matty21's Avatar
are you talking about the turbo fart ?the 6.0L did it , the 6.4L did it , so does the 6.7L not to worry too much
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #7 of 14 Old 10-06-2011, 07:52 PM
Quoted: 4 Post(s)
Ditto, are there ANY remedies???
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #8 of 14 Old 10-06-2011, 07:52 PM
matty21's Avatar
one remedy is just keep it floored
if it happens when you let off the throttle , then dont let off the throttle.
but seriously, it has to do with the trans . keep it in tow/haul and it wont do it ever again
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #9 of 14 Old 10-07-2011, 05:52 PM
Is the turbo fart the sound that follows a high rev, when you're just revving the p**s out of it in park?
I'm referring to the sputtering/backfire type sound from the intake at low revs in high gears, 5th and 6th usually. Happens randomly when pulling hills at low rpm, usually when it's right on the verge of having to downshift, around 10 psi boost and 900-1000 rpm.
I haven't tried driving in tow/haul but that's not something I really want to do all the time. I'm sure my truck did this before I did the mods, I can just hear it better now that it's not muffled by the stock intake.
mmars89 is offline
post #10 of 14 Old 10-07-2011, 06:09 PM
Galaxie's Avatar
Oh yea! You guys have some turbo fart! And, you can hear it with aftermaket intakes!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
