6.7 Turbo Noise, Anybody have any ideas? - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 7 Old 09-26-2011, 07:01 PM Thread Starter
Okay I got my truck serviced the other week and notices the fan would stay on alot longer then it did before. Looked at the temps and the oil temp seemed a little higher then normal. So I'm thinking they used the wrong oil maybe. So i took it back and they changed it again with the right oil and now the Turbo is making like a siren sound, really annoying load whitsle. Sounds like it's coming from the Turbo. Anybody have any thought on this?
Ahay1313 is offline
post #2 of 7 Old 10-06-2011, 10:41 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Any Updates?
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 7 Old 10-24-2011, 04:22 PM
Mine does the same thing interested to see what it is it makes loud noise around my shift points
strokin9 is offline
post #4 of 7 Old 03-03-2012, 09:29 AM
Mine does this same thing... After driving around and coming to a stop, it sounds like the vanes of the turbo and turbo speed increase (siren sound) and the boost gauge creeps up above zero, slightly (reminder, this is at a dead stop at idle). After cycling like this 2 or 3 times, it stops usually. Not sure if this normal or if there is a leak or something not allowing the vane pitch or something to settle at idle. Anyone else?
Strokin'Hokie is offline
post #5 of 7 Old 03-06-2012, 10:08 AM
Dr.Evil's Avatar
From what I heard it is caused by the variable geometry turbo closing the vanes to maintain operating temps. So when its cold out you will hear it spool up a bit at idle. Its a lot more noticeable with DPF delete. I don't remember it being very loud at all with the stock exhaust. Just an idea.
2011 F-250 Lariat Ex LB 6.7
2001 F-250 R.C. LB 7.3
Dr.Evil is offline
post #6 of 7 Old 03-06-2012, 10:22 AM
Bryce18's Avatar
Quoted: 19 Post(s)
Yup, ive noticed this as well. especially after driving then parking and getting out while its ideling. it sounds like the turbo spools up just a little bit then unspools. mine has done it 3-4 times after parking before.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #7 of 7 Old 03-06-2012, 07:09 PM
Mine does the same thing, so I'm hoping this is normal. I'm deleted by the way.
cc2cuz is offline
