rattling at idle - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 4 Old 02-23-2011, 09:18 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
rattling at idle
hello,
got an 04' 6.0L with 129,000 on her. question is when the truck is sitting and idling it makes a rattle/clatter noise. Almost sounds like it is coming from the fan/fan clutch. Have had ford look at it and they said everything is good to go and couldn't explain it. When the truck goes into high idle, it immediatly goes away.
Thoughts or experience, thanks.
04' F-250 6.0L
AFE Stage 2 intake
Liberator EGR delete kit
MBRP up pipe assembly
4" MBRP Turbo back (straight piped) WHISTLE
zoodad mod
Nitto Dura Grapplers
Edge Insight CS
DieselSite Coolant Filtration
Upgraded fuel pressure spring kit
upgraded turbo oil supply tube(solid)
upgraded turbo drain tube
SWAMP's 48V FICM
Rotella ELC
Firestone Ride Rite air bags in rear
draw-tite 30k hide-a-goose kit
scha0786 is offline
post #2 of 4 Old 02-23-2011, 09:19 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
wrong area, sorry
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
post #3 of 4 Old 05-08-2012, 09:12 PM
Did you ever find the problem? I had the same rattle. Its the little actuator piece that rides on the front of the clutch to lock it when the engine gets hot. Took me about 5 minutes to find it. Just have the remove the upper shroud to see it.
streetrod54 is offline
post #4 of 4 Old 05-12-2012, 07:17 AM Thread Starter
scha0786's Avatar
Quoted: 24 Post(s)
yes,
hard to explain without a picture but here we go:
if you open the hood and look to the right on the radiator shroud, you'll see a black plastic plug. Follow that down to the fan shaft. There you will find an aluminum collar around the shaft, that is what is rattling on mine. Never bothered to fix it cause I am sure a new on will do the same problem.
I found it when I was replacing the oil cooler and radiator on my truck like 1 year ago.
04' F-250 6.0L
AFE Stage 2 intake
zoodad mod
Edge Insight CS
SWAMP's 48V FICM
Rotella ELC
scha0786 is offline
