Engine shut down on me in the middle of a busy road for no reason!? - Ford Powerstroke Diesel Forum
6.7 Motor Problems (2011-2016) 6.7 Motor Problems
post #1 of 12 Old 01-08-2011, 09:00 PM Thread Starter
I was pulling my first big load today with my truck. I have about 3200 miles on her. Pulled the 10,000lb forklift on a trailer just fine...until I tried to give it the beans going up a small hill and the truck pulled but shuttered to the point where my passengers even noticed it. only mods I have are the AFE and the MP-8, which I had turned up at the time. The shuttering felt like it came from the tranny and I felt like I should let off. Again, it was only noticible at more than half throttle. The BIG problem I had today though was later in the day when I was on a busy 4 lane road just about to go up a small hill and the truck (engine) just died. Drove perfectly normal one minute and just plain cut out the next. As I was coasting with no power and no way to get over ot the curb lane my first thought was to look for warning lights or hot temps but the dash showed nothing was wrong. My second thought was that I had run out of DEF and it was going into idle mode but it didn't even idle. It was just plain off. Had electric but no motor. As I came to a stop I checked the DEF fluid level in the menu and it said under half full but that's it. I don't belive this to be the problem. SO anyway, I put it in park, turned the key off, and tried to start it and luckily it fired right up and I got moving again. Was fine after that. I also noticed later that day that I was getting that popping or chuch chuch chuch sound that I have been noticing since I put on the AFE. Still does that randomly oncein a while and I can't make it do it at will. Usually happens just as I let off the throttle or just when I am starting to give it very light throttle. Mostly when letting off lightly though. Any thoughts on any of this? Going to go to dealer with it soon for oil change and to have them check it out. I am mostly concerned about the truck leaving me stranded in the middle of a busy road with a load on ....in the middle of a hill. Was not a fun experience. WTH?
DieselSmokeM35A2 is offline
post #2 of 12 Old 01-09-2011, 07:21 AM
matty21's Avatar
what were the weather conditions
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 12 Old 01-09-2011, 08:54 AM Thread Starter
The temps were in the low 20's. It had snowed a little so the roads were dry in some spots and a little wet in others.
post #4 of 12 Old 01-12-2011, 02:01 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
WHat did the dealer say?
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, TW tunes, 4" DP, Napa Intake, coolant filter, 140cc Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #5 of 12 Old 01-12-2011, 06:04 AM Thread Starter
Haven't had the opportunity to take it in yet. Has been fine since so far.
post #6 of 12 Old 01-12-2011, 05:06 PM
Took my AFE off had the same problem, the popping/puff puff noise you are hearing is the waste gate activating. This truck does not like the AFE filter kit and its been noted in other forums. Since I removed my AFE I do not have that problem.
jacob678 is offline
post #7 of 12 Old 02-20-2011, 06:08 PM
i have 2 issues with the 2011 6.7 motor. 4000mi now. just put on afe stage2 and def-back exhaust. hard to believe but i think im getting worse milage now! just hauled a skid loader on trailer(@10k total) and got jist over 9mpg at 55mph--terrible mpg. issue #2..4 times now(3before and once since afe installs) the engine would not accelerate or take off when i hit the throttle. it acts like a cold motor does when you try to accelerate when its too cold. it just dies down. it does not stall out just wont go above an idle.no rime or reason or common thread except its always from a stop and scary cause i've been facing traffic each time... ford says no reports or bulletins...any help or similar experiences thanks..dc.smowball
dc.snowball is offline
post #8 of 12 Old 02-21-2011, 06:29 AM
mor4wd's Avatar
DPF back exhaust isn't going to help you in anyway in terms of horsepower or MPG. It seems like majority of people who are having any problems are adding aftermarket parts. Don't get me wrong, I'm all for tuning your truck, but I'd try removing all aftermarket parts and see if you have any problems then.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #9 of 12 Old 02-21-2011, 07:30 AM
i'd remove your intake and see if that doesn't help. Trial & Error
Jimmy7060 is offline
post #10 of 12 Old 02-25-2011, 08:29 AM
had the idle only conditionbefore and after the afe intake
