6.7 Single Turbo (S363) upgrade problems - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-14-2014, 03:17 PM Thread Starter
while installing an S363 turbo in my 6.7 ford powerstroke I managed to drop a bolt into the engine block through the oil port underneath the turbo pedistool I have tried fishing it out through the oil port on top as well as through the bottom with oil pan removed with no success any and all help is appreciated !!!!!!! thanks also I would like to announce that Maryland diesel will NEVER be recommended to anyone from me !!!!!
BillySabo is offline
post #2 of 2 Old 01-07-2017, 10:34 AM
Quoted: 4 Post(s)
Another guy did this exact thing not long ago. He was told to drop the bottom oil pan and check if it's in there. The other option is drop the upper oil pan but that required dropping the transmission. A tech told him most likely it will fall through to the bottom oil pan eventually. The hole it fell in is the oil return as it goes through the turbo so it shouldn't hurt anything. If it's a large bolt it may get wedged and stick there. Are you 100% sure it did go into the hole and not somewhere else. Who's tunes did you get? I bought the s363 kit last January and had to get different tunes since the first I got had really poor spooling and low mpgs. I have the video on Youtube for the s363 installation. I definitely recommend the intercooler piping kit to help the spool up and top end power.
6.7 Powerstroker is offline
