Rear bumper flood lights - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Bryce18
post #1 of 10 Old 03-10-2014, 10:39 AM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
A few weeks ago I installed some rear flood lights. Result was great. They work as awesome work lights and aid in reversing. I ended up wiring them to a up fitter switch along with tapping into my reverse lights.
The lights are 7" single row LED light bars.
I mounted them to 8" pieces of angle iron and then bolted them to bottom of rear bumper.
ID:	255698   Click image for larger version
ID:	255706   Click image for larger version
ID:	255714   Click image for larger version
ID:	255722   Click image for larger version
hansel and Silvin like this.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #2 of 10 Old 03-10-2014, 10:41 AM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
More pics
ID:	255738   Click image for larger version
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #3 of 10 Old 03-12-2014, 05:04 AM
Haushd's Avatar
Nice, that would be great for hooking up to the trailer, along with some lights in the box for under the tonneau. Wish i as more of an electrician to figure out the upfitter switches, good work!!
Haushd is offline
post #4 of 10 Old 03-12-2014, 05:17 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Looks great Buddy!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 10 Old 03-12-2014, 05:55 AM
hansel's Avatar
Quoted: 89 Post(s)
I like that, where did you get the lights???
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #6 of 10 Old 03-14-2014, 04:40 PM
those look identical to the lights I bought off of amazon the 2X 18W led work lights??? 42.80 for the set???
2011 F350 DRW lariat Spartan tuned, 4" straight piped exhaust,afe stage 2 CAI,SDP egr delete and more coming
Sold 12 ram 2500 and dont miss it!!!
E99 F350 7.3L parts on the way
skinnysfd is offline
post #7 of 10 Old 03-14-2014, 07:53 PM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
I got mine off amazon but they weren't sold in pairs. They were like $23-24 / light. But you're right they are probably the same lights Haha.
How did you mount them in your grille?
Did you bolt to grille or make brackets?
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #8 of 10 Old 03-14-2014, 08:15 PM
I had to cut out the pieces of grill and grind out some in back but ended up using the brackets supplied and bolted em right up . I really like them and have another set I'm throwing in the back and then going to get some amber ones for around the front more like chicken lights maybe
post #9 of 10 Old 03-22-2014, 06:17 PM
Is the wattage low enough that you could just tap these into your reverse lights so they come on when you go into reverse?
'02 F250 PSD XLT CC
losrocket is offline
post #10 of 10 Old 03-23-2014, 08:32 PM Thread Starter
Bryce18's Avatar
Quoted: 17 Post(s)
Yes works great. Mine come on w/ reverse lights and/ or upfitter switch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
