Help Recon Big Rig Lights..... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-09-2014, 06:45 PM Thread Starter
bowzer's Avatar
Quoted: 2 Post(s)
ok got these lights and not sure how to mount as one of the supports for the running boards blocks the lights when mounted how they "should" be. Put on the outside of the mounts doesn't look right. If anybody has them can you post some close up shots how you mounted them?? Thinking cutting the plastic trim of the mount but not sure.......
Oh and the are the longer length ones.
Thanks!!!!!!
David
2013 F250 Platinum 6.7
2010 Expedition EL Limited
2013 Coachman Freedom Express 298reds
2004 Crownline 225LPX
5 Mustangs
My website:
www.mustanggt.org
bowzer is offline
post #2 of 4 Old 03-10-2014, 04:00 AM
SHOWOFF's Avatar
Do you have aftermarket steps or the stock chrome ones? Trying to picture what you are talking about to help you.
2014 F250 Plati
SEMA 2K15
Krazy Nikel
SHOWOFF is offline
post #3 of 4 Old 03-11-2014, 12:42 PM
Alberta Advantage's Avatar
Quoted: 17 Post(s)
If you PM me your email address, I can send a picture do my Recon lights and how I mounted them with NFab steps. I couldn't mount them on the pinch weld because of the steps. I mounted them on the piece adjacent to the pinch weld. I get very good "glow" on the ground and they're visible to others too where I mounted them.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #4 of 4 Old 03-11-2014, 04:45 PM Thread Starter
bowzer's Avatar
Quoted: 2 Post(s)
I have the factory steps
David
5 Mustangs
My website:
www.mustanggt.org
bowzer is offline
