Easy tailgate emblem mod! - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-01-2014, 01:39 PM Thread Starter
I'm sure many have done this, but for those who haven't are concerned I'll tell you it's a breeze! I ordered a new emblem off of eBay for $50. It's painted to match my king ranch theme. I was worried how hard it would be to pull old emblem off. Within 10 mins I had old emblem off and new one installed. I used a small pry bar, a little heat and a towel (to avoid scratches). Figured the sticky adhesive would be a pain but it rolled right off. A little alcohol scrubbing and it was good to go!
t korkle is offline
post #2 of 19 Old 03-01-2014, 01:59 PM
POWERCHOKER
Dantron's Avatar
Here's one made by DefenderWorx® for a tailgate emblem with back-up camera. At first they sent me one intended for no back-up camera. However, they sent me a tailgate emblem designed for the F-150 with back-up camera, which ended up being the same size. I still have the tailgate emblem designed for no back-up camera, which I think is 9 inches across. There is a slit on the underside of the rear tailgate emblem w/ camera which lets you pop it off with a pocket knife or thin screw driver. Unfortunately, it was close to $200 for me to buy matching front and rear emblems from DefenderWorx® and the grille emblem WAS NOT "Plug & Play".
Dantron is offline
post #3 of 19 Old 03-01-2014, 02:08 PM Thread Starter
Looks good dantron! I hadn't front end painted to match and got my painter to do grill emblem also. He wouldn't do my back one, So I found this one on eBay. Happy with them both!
t korkle is offline
post #4 of 19 Old 03-25-2014, 05:00 PM
So you installed your truck upside down? JK
Krazymaan is offline
post #5 of 19 Old 03-25-2014, 07:22 PM Thread Starter
Lol idk why it does that sometimes! Drives me nuts
t korkle is offline
post #6 of 19 Old 03-30-2014, 04:22 PM
brmccolley's Avatar
Try again
I have the same color scheme. I plan to do the same. Here's the picture flipped.
brmccolley is offline
post #7 of 19 Old 04-01-2014, 05:19 PM
barobbin's Avatar
Quoted: 3 Post(s)
Looks good! I replaced mine with black ones. The best way I found to remove them is with some fishing line. I used power pro. Just saw the adhesive behind the emblem then peel adhesive off
barobbin is offline
post #8 of 19 Old 04-01-2014, 05:58 PM Thread Starter
Thanks man! Yea I forgot to mention I used that as well. I kept getting hung up on the 3 line up tabs that are on these tailgate emblems but it did help for sure! Where did you get your black emblems at?
t korkle is offline
post #9 of 19 Old 04-04-2014, 02:10 AM
Quoted: 4 Post(s)
I've seen emblem overlays on ebay. Does anyone have tried using it?
truckfan is offline
post #10 of 19 Old 04-09-2014, 03:28 PM
Ontario Trucker's Avatar
I've seen them on trucks, they don't lay flat & its easy to tell its a decal, just my .05
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
