Suspension Alignment Lift Kit - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-29-2014, 04:10 PM Thread Starter
jacobdewey's Avatar
I'm wanting to throw some 2.5" Icon coils with 1.5" spacers in my truck (blocks in back and new shocks all around) My question is what would I have to do to make the sure my caster, camber, axle alignment ect, ect. stayed in spec? Do I need an adjustable track bar? New 4 link?
Would I be cheaper to just buy a 4.5 Carli or Icon kit?
2011 CCSB, 20x9 -12mm Badlands, H&S, S&B, Katzkin, DDM 5k, 1.5" leveling kit, 35" AT II's.
jacobdewey is offline
post #2 of 13 Old 01-30-2014, 07:47 AM
Skyd Ram's Avatar
Quoted: 61 Post(s)
At that height you will need the following to do it "right"
Adjustable track bar
Sway bar drop brackets or longer end links
Brakeline relocation tabs or longer brakelines
Radius arm drop brackets. new radius arms, or a 4-link conversion
Yes,
At that point you would be best off doing an engineered system.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
The Following User Says Thank You to Skyd Ram For This Useful Post:
jacobdewey (01-30-2014)
post #3 of 13 Old 02-07-2014, 06:47 AM
barobbin's Avatar
Quoted: 3 Post(s)
Skyd what about with just 2.5" ??
barobbin is offline
post #4 of 13 Old 02-07-2014, 07:01 AM
Quoted: 2 Post(s)
Have you looked at the readylift 2.5 p/n 69-2511
2011 F250 6.7 3.55 gears
20" wheels,
Tonneau cover,
Chrome mirror covers and door handles,
Line-X bed liner,
LED grille lights amber,
EZ-down tailgate,
Tinted windows,
3.5"Ready lift kit
Amp steps
Bigtwinharley is offline
post #5 of 13 Old 02-07-2014, 07:22 AM
barobbin's Avatar
Quoted: 3 Post(s)
Yeah I have. Didn't want to do spacers. I already have Carli progressive 2.5" coils and 4.5" tgc block and nighthawk shocks. Haven't installed yet. Just looking if I need anything else. Going to probably order a carli trac bar
barobbin is offline
post #6 of 13 Old 02-07-2014, 07:43 AM
Skyd Ram's Avatar
Quoted: 61 Post(s)
In addition to the coils you will need:
Longer shocks
Caster Cams
Front brake line extension tabs
Something to lift the rear if it's an F250
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
post #7 of 13 Old 02-11-2014, 01:25 PM
Quoted: 2 Post(s)
1999-2012 Ford F-250 Super Duty Camber and Alignment Kit - Raybestos, Direct fit, Bushing, Front - JCWhitney
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #8 of 13 Old 02-11-2014, 02:19 PM
Pure has a 4" lift with everything you'd need. I think that would be a better plan than buying a 2.5" and adding a spacer on top.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #9 of 13 Old 02-11-2014, 04:15 PM
Quoted: 2 Post(s)
check out BDS too if you are shopping around. My lift is simple and rides awesome.
wreedPS is offline
post #10 of 13 Old 02-12-2014, 06:51 AM
Quoted: 2 Post(s)
Feedback Score: 5 reviews
Best results will be by getting a new kit, I'd highly recommend a 4 link kit as it helps the ride quality and allows correct castor..4.5* to be set.
We carry both Pure performance and Icon. PM me if I can help.
CT Performance, Inc. is offline
