cab lights install wiring - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-25-2014, 07:45 AM Thread Starter
I got the oem lights with harness, but I dont think its the right one. It only has the plugs for lights and sat. Nothing for air bags, ect. Question is I'm actually fine with not having to remove an entire harness to install another one, but if I run the power wire down under dash where would I tie it into so that they work with everything including remote start? Could I connect ground under there too somewhere or could I just connect that to sunvisor clip above headliner? Pix would be great with explanation.
Thanks
2006 F-350 6.0 crew cab long bed with line x.
2" leveling in front with 315/65/18 BFG's.
Billet grill
MBRP 4" duals, AFE stage 1, Tunes from Eric @ Innovative and DJ's.
Overhead pod with Isspro guages
Jarods gerbils is offline
post #2 of 11 Old 01-25-2014, 02:17 PM
zpd307's Avatar
I would like to know also. have you checked to see if the harness is dead ended up above the headliner?
hello, my name is gary
new: 2008 f250 lariat 4x4 ccsb 6.4.....
sold,2011 f250 xlt 4x4 crewcab 6.2 shortbox 5 star tuned
sold,early, 09/98, 1999 f350 lariat 4x4 crewcab 7.3 dually
sold, 1990 f350 lariat 4x4 crewcab 7.3 longbox.
sold, 2003 f350 lariat 4x4 crewcab 6.0 longbox.
1987 we4 turbo buick
2008 taurus limited
zpd307 is offline
post #3 of 11 Old 01-25-2014, 03:08 PM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Correct, the wiring harness is already there in the headliner, just add lights and plug it in. That's the way it was on my '11 XLT that didn't come with the clearance lights. I added them afterwards. The kit came with a template to drill the holes. Turned out pretty good I thought. Def. cheaper to buy a truck that already has them from the Factory.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 11 Old 01-26-2014, 07:14 AM
zpd307's Avatar
thank you sir. did you drop the headliner when you installed them?
2008 taurus limited
zpd307 is offline
post #5 of 11 Old 01-26-2014, 07:37 AM
Quoted: 3 Post(s)
I didn't let it drop all the way because the shavings from drilling the holes would have gone all over the place. I only needed enough room to get the lights attached to the harness. Dealer wanted $400.00 to install them!
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #6 of 11 Old 01-26-2014, 07:45 AM
zpd307's Avatar
yep, crazy. on another note, did your truck have satellite radio. mine doesn't and I ask, because I am curious if the sat radio antenna wiring also dead ended up above the headliner. I am gathering the items to put in factory nav and will probably go with the roof antenna and I could put in cab lights at the same time. the truck doesn't look right without cab lights.... I found the part number for the main sat radio antenna harness.
2008 taurus limited
zpd307 is offline
post #7 of 11 Old 01-26-2014, 07:52 AM
Quoted: 3 Post(s)
There are those will disagree but I'm with you, these trucks don't look right without roof clearance lights!
My '11 didn't have the sat radio wiring but your truck might have it. If ya help with the Nav. give Steve on here a holler (sredmyer) I think is his screen name. He does this all the time and gave me pointer's with mine. Do a search for factory Nav. you should find him that way if nothing else works. He will have all the part #'s.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #8 of 11 Old 01-26-2014, 08:03 AM
zpd307's Avatar
yeah, I have read and read on the subject. lots of threads with great info. I was originally just going to use the magnetic puck that goes under the dash. I had to do this when I installed factory nav in the wifes 08 Taurus. but since sat radio and gps now use the same puck and sat radio is built into the nav unit, I was curious to see if ford already had the antenna prewired up the a-pillar. might just have to pull the a-pillar cover off and find out.
2008 taurus limited
zpd307 is offline
post #9 of 11 Old 01-26-2014, 05:55 PM Thread Starter
I'm not really sure how your harness was already up there for cab lights, typically you have to purchase a new harness and replace an existing harness. I got the wrong one so just ran power wire down and ground wire down and spliced it directly into wires where harness was supposed to tie into anyways. Works great just hard to get hands up there to work.
Billet grill
post #10 of 11 Old 02-17-2014, 03:54 PM
HighHP's Avatar
So one of you had 5 plugs in the roof already for the cab lights and the other didnt? Messed up, I guess I better pull my headliner down and take a look inside before I go ordering the harness to install my lights.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
