Just need a couple more inches - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 9 Old 01-17-2014, 06:06 PM Thread Starter
Looking to get a couple more inches of lift without shelling out too much cash. I have a pro comp 6" right now. Is it possible to add a spacer kit to the top of the coils to achieve an extra bit of lift?
I could even handle an inch, just need to take care of some minor rubbing
2012 f250 6.7
6" rough country lift
37" trail grapplers
20x12 fuel hostage
awg8 is offline
post #2 of 9 Old 01-17-2014, 06:57 PM
Heavy_GD's Avatar
Quoted: 764 Post(s)
Feedback Score: 3 reviews
yes you can.
GD - 06 CCSB FX4 Lariat
Originally Posted by G8orFord View Post
My magic wand broke a few years back when my crystal ball fell on it. Ruined the ball too. So we're going to have to figure this one out another way. YOU NEED A MONITOR or at least a good scanner.
Heavy_GD is online now
post #3 of 9 Old 01-21-2014, 04:35 AM
SHOWOFF's Avatar
I threw an inch spacer on top of my 6 inch to get rid of my rubbing. It worked.
2014 F250 Plati
SEMA 2K15
Krazy Nikel
SHOWOFF is offline
post #4 of 9 Old 01-21-2014, 05:41 AM Thread Starter
What kit did you get? and did you need re alignment? also, what did you do about the rear, does it have the bulldog stance?
Thanks
2012 f250 6.7
37" trail grapplers
20x12 fuel hostage
awg8 is offline
post #5 of 9 Old 01-21-2014, 07:24 AM
sbluke55's Avatar
Quoted: 273 Post(s)
Personally I would find a taller spring to get the heigh you want. The spacer are ok but they can start to make noise. Also keep in mind if you go taller you may need longer shocks.
01 f-250, Standard
Rev tech 4" lift,35" Mickey Thompsons MTZ
KC diy 66 stage 2, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
[/LEFT]
sbluke55 is offline
post #6 of 9 Old 01-22-2014, 12:57 AM
Heavy_GD's Avatar
Quoted: 764 Post(s)
Taller shocks, yes, but not sure on the noise since I only have a couple thousand miles on mine
FWIW, I went with the aluminum block at the bottom and have had no issues.
I also didn't get an alignment.
post #7 of 9 Old 01-22-2014, 04:01 AM
SHOWOFF's Avatar
Thanks
I did a 6" top gun customz lift kit, and then added a 1" spacer from them as well. I didnt notice any driving differences or noises. I got a reallignment just to make sure everything was straight and good.
2014 F250 Plati
SEMA 2K15
Krazy Nikel
SHOWOFF is offline
post #8 of 9 Old 01-22-2014, 04:16 AM
sbluke55's Avatar
Quoted: 273 Post(s)
I recommend doing an alignment. When you taller it has a tendency to change your caster, which affects your return to straight after turns and it makes it kind of squirrelly
01 f-250, Standard
[/LEFT]
sbluke55 is offline
post #9 of 9 Old 01-22-2014, 05:24 AM
ZWilson07's Avatar
Shocks might not be necessary if you are only going up an inch; most shocks are rated for a small section of height anyways, but I would double check with the manufacturer to make sure on your particular setup.
Definitely get an alignment. I don't know how it is around you, but around here if you go in and the alignment is still within specs, they will let you leave no charge. So there is really no good reason not to at least have it checked out.
Even if you need an alignment for just a slight change out of spec, whats ~$75 compared to your 40k-50k truck with a good 3-5k in lift, wheels, and tires right?
Goodluck
  • 1990 F250 RCLB 7.3 IDI 4x4 ZF5. 45,000 original miles and factory original as can be.
  • 2006 Dodge 3500 QCLB DRW 5.9 CR G56.
  • Vehicles for days!
Will never buy anything from IPR and Sinister! List still growing
ZWilson07 is offline
