Rust Protection - Ford Powerstroke Diesel Forum
post #1 of 18 Old 12-28-2013, 06:41 AM Thread Starter
Jquickie's Avatar
Rust Protection
Just wondering what you guys are using for rust protection on your power strokes? I currently have been getting my old truck oil sprayed every year. It works good but it's messy. With my new truck arriving in a couple of months I'm trying to figure out what's best to use? Any suggestions?
Jquickie is offline
post #2 of 18 Old 12-28-2013, 09:22 AM
I was thinking of having my truck done by ziebart, but I'm undecided. They say if it's not done properly it can actually be worse then it was uncoated due to water getting trapped inside and what-not. I'm curious to hear from other people have done for rust protection though.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #3 of 18 Old 01-02-2014, 06:44 AM Thread Starter
Jquickie's Avatar
Anyone using rust protection in the northern areas?
Jquickie is offline
post #4 of 18 Old 01-02-2014, 07:03 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
If you have Z do it you better watch them like Hawks or your interior will be just as Rust Proofed!!!
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 18 Old 01-04-2014, 04:48 AM
^And your paint, window, wheels, trim................
2012 F250 XLT CC SCORPION
2011 GG EVO X
eve-slow is offline
post #6 of 18 Old 01-04-2014, 10:37 AM
damn,
ya I asked them and they said they don't allow anyone in the shop while it's getting sprayed. I may end up passing then.
Soon to install..
post #7 of 18 Old 01-04-2014, 05:31 PM
I use fluid film on all my vehicles!
I got a 5 gallon bucket of it and I use a sand blasting gun kit to apply it!
You tube it the stuff is amazing!
We use if for everything!
Wallace is offline
post #8 of 18 Old 01-06-2014, 06:23 PM
ucpa111's Avatar
Quoted: 2 Post(s)
+1 for Fluidfilm. It was developed by the Eureka company for use on Navy vessels. It's easy to apply with an air gun and I think it's cheap insurance. I live in NW Pennsylvania and they put all kinds of nasty stuff on the roads. I used Fluidfilm on my Tundras with awesome results. 6 winters and no rust to speak of on the frames and nothing on sheet metal. Buy the right gun and air nozzle and you can coat inside panels/doors/etc.
I reapply annually after a good pressure washing underneath. Because it is a lanolin wool wax, it's not harmful for you either (well..unless you guzzled it or something LOL).
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #9 of 18 Old 01-06-2014, 06:35 PM
HighHP's Avatar
So this fluidfilm stuff is more of a water repellant that eventually wears off and you just re apply it yearly?
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #10 of 18 Old 01-06-2014, 06:40 PM
WNY Biodiesel Co-op
greasyF250's Avatar
I buy the gallon of cp90 rustproofing from Carwell and spray it on with a siphon gun from Eastwood. Works great and it displaces water.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
