1" Leveling kit & 37 Trailgrapplers - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 10 Old 11-22-2013, 08:01 AM Thread Starter
Just got my leveling kit and tires on. Got a 1" Top Gunz Customs leveling kit and a set of 37x12.50R20 Nitto Trailgrapplers. Made a huge difference in looks. Only rubs in one place (will post picture below). The rusted over rub mark on the bar is from my 35s, the fresh in from the 37s, still have full turning radius, just rubs side wall slightly. Also color match Ford symbol in grille, and the back area of the F250 side logo.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
THarpe2566 is offline
The Following User Says Thank You to THarpe2566 For This Useful Post:
Paul's Powerstroke (11-22-2013)
post #2 of 10 Old 11-22-2013, 08:11 AM
kirbybc12's Avatar
Looks great! What 35s did you have on before? I'm trying to figure out if it will rub if I go 12.5 with the leveling kit on.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #3 of 10 Old 11-22-2013, 08:56 AM
Looks real good, where did you get the painted emblem?
Swampfox is offline
post #4 of 10 Old 11-22-2013, 11:45 AM
Paul's Powerstroke's Avatar
Quoted: 2 Post(s)
This post was exactly wanted I needed to see. This is the setup that I like. Thanks for posting specs and pictures. Awesome looking rig.
2013 F-250 Lariat FX4 CC Kodiak Brown Metallic
2015 Puma Unleashed Palomino 351-THSS 37' 5'er Toyhauler
"Just put that hammer down and give it hell" - Jerry Reed.
Paul's Powerstroke is offline
post #5 of 10 Old 11-22-2013, 01:43 PM
Powerstrokin_08's Avatar
Do you think the 35's would still rub after the 1" puck? And how is the stroke on the shocks now? Do they still have plenty left or close to full stroke? Thanks.
2013 King Ranch F-250 CCSB 6.7L 4x4
Carli 2.5" Leveling Kit
4" Rear blocks
Bilstein 5100's
AMP Research steps
Plain and Simple Custom Headlights
35" Toyo MT's on King Ranch rims
Fab Four Black Steel bumpers front and back
*SOLD*2008 F-350 CCSB 6.4L 4x4
4" DP back
H&S Mini Max
Sinister EGR/Cooler Delete w/Intake Elbow
Carli 2.5 Pin Top Suspension
S&B CAI
NC Hornet CCV mod
20's&35's
Powerstrokin_08 is offline
post #6 of 10 Old 11-22-2013, 09:41 PM Thread Starter
A 1" sits perfectly level on it. I had 295/65R20 nitto trailgrapplers which is like a 35.7 but narrow. I had previously replaced the shocks with bilsteins before I put leveling kit on it. As for the emblem i took it off, and it splits into 3 parts, then sanded, primed, and painted the exterior part. It was time consuming. Turned out good though. Just ask if you have any other questions!
Powerstrokin_08 (11-23-2013)
post #7 of 10 Old 11-23-2013, 03:50 AM
Thanks for the info. I want to do the same thing and keep this truck nice and modest no big lift or anything. Do you think that with a different wheel and offset the tires wouldn't rub on the radius arm? And truck looks awesome by the way. I did the same thing on the emblem on my old truck but black.
4" Rear blocks
Bilstein 5100's
AMP Research steps
4" DP back
H&S Mini Max
S&B CAI
NC Hornet CCV mod
20's&35's
post #8 of 10 Old 11-23-2013, 08:08 PM Thread Starter
Going to a wider offset would cure the rubbing on the trac bar, however I believe you would then run into problems with hitting the bumper and the outer bumper brackets. Personally I would rather it rub a small amount on a smooth surface like the trac bar, rather than a jagged surface like the corner of the bumper or the bumper mount bracket. Overall I am extremely happy with the turnout, may go with a little bit larger leveling kit just because I like my truck up in the front a small amount.
post #9 of 10 Old 11-25-2013, 05:35 PM
IA Farmer's Avatar
Does the emblem come apart without breaking any tabs and go back together easy, or do you have to glue it back together? Also do you know if the tailgate emblem comes apart the same way?
2013 F-350 CCSB Platinum
2010 F-250 CCSB Cabelas Edition - Sold
IA Farmer is offline
post #10 of 10 Old 11-25-2013, 08:45 PM Thread Starter
Tailgate does not come apart like the front it must be taped off and sprayed, it is two sided taped to the tailgate. Huge pain taking it off. The front has a ton of small plastic clips you must be careful with them. I broke a few but not enough where it would not stay together. I did put a small amount of glue just to be sure it wasnt going anywhere.
