receiver for trailer hitch - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-24-2013, 03:53 PM Thread Starter
where is the best place to buy towing accessories For an f250? I have been told that BWI* I think it is has good receivers. Thanks!
Alamo707 is offline
post #2 of 14 Old 09-24-2013, 09:24 PM
I have a B&W tow and stow tri-ball. It folds up and under the truck when not in use and I think it is rated up to 10k lbs.
Swampfox is offline
post #3 of 14 Old 09-24-2013, 09:56 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I use the Rapid Hitch 4" adjustable with grease-less coating on each ball. Give me 8" of actual adjustment since they can be turned upside down. If you decide on this set up get the $40 lock kit... Comes with two locks, one for the receiver and one for adjustment piece. With the locks not even the balls can be stolen with simple hand tools.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 14 Old 09-25-2013, 03:33 AM
SHOWOFF's Avatar
I have a Diversitech 6inch drop for sale.... Adjustable, locking, and has a 2 5/16 ball and 2 inch.
2014 F250 Plati
SEMA 2K15
Krazy Nikel
SHOWOFF is offline
post #5 of 14 Old 09-25-2013, 04:43 AM
Dual ball b&w here
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #6 of 14 Old 09-25-2013, 06:39 AM
chancelor's Avatar
all chrome B&W dual ball hide away! Looks good folded under and rated for 10k !!! a little expensive but well worth it!
2006 F350 4X4 Lariat... Just getting started with this one... afe air intake, edge juice platinum with attitude, coolant filter kit, high idle switch added, blue spring conversion Fan clutch switch, daystar leveling kit, zoodad, a few extra lights, custom gooseneck hitch and air bags on the rear
chancelor is offline
post #7 of 14 Old 09-25-2013, 10:21 AM
Alberta Advantage's Avatar
Quoted: 18 Post(s)
I used to have a B&W Tow & Stow adjustable hitch and it would constantly seize up as it was made of steel. Pins would rust in the holes and make it impossible to adjust without punching them out with a hammer. I now have an aluminum hitch, the Diversitech posted above that is great. Weighs a lot less than the BW steel hitch and no more seized pins.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #8 of 14 Old 09-25-2013, 09:47 PM
Mine has never seized up but I also do not live in Antarctica. A little grease on the pins goes a long way too.
Swampfox is offline
post #9 of 14 Old 09-26-2013, 07:31 AM Thread Starter
Ok So here is where I am. My truck has the 2 1/2 " slot so I guess I will need to buy an adapter to be able to use a b&w hitch? Any suggestions on the best agapter to reduce ? I see complaints about sloppy loose play with some adapters. Thanks!
Alamo707 is offline
post #10 of 14 Old 09-26-2013, 09:11 AM
SHOWOFF's Avatar
Your truck lifted? I have a diversitech I will sell you! 6 inch drop Adjustable! 2 1/2 shank! fully lockable with keys and double balls (2 & 2 5/16). Solid aluminum. Best on market! Only reason I'm selling is because I went to a 10 inch drop one after I lifted my truck. Let me know.
2014 F250 Plati
SEMA 2K15
Krazy Nikel
SHOWOFF is offline
