Rear blocks for a "leveled" F250 - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 23 Old 08-25-2013, 12:25 PM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
a buddy of mine has a 2011 6.7 crew cab short wheel base 4x4 it looks like the previous owner put a 2.5" leveling block up front on top of the spring, but did nothing to the rear and it looks like it sags ***. What would be the best setup of blocks and u bolts for the rear to level it out? what height block should we use? will the factory shocks have to be changed out or will they still work with the new blocks. Also how hard is it to swap these out? I have a 350 and didnt have to touch the rear.
Casey
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 23 Old 08-25-2013, 12:29 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 214 Post(s)
You need to get either factory F350 blocks which are a little under 4" or just order a ready lift 4" block and ubolt kit.
http://www.xtremediesel.com/readylif...it66-2014.aspx
Keith
2014 F250 Platinum FX4
AFE Intake
Sct x4
4" Dual Exhaust no muffler with 5" MBRP tips
4" BDS with Fox shocks
20x9 Gear Alloy Big blocks 0 offset
35" Toyo AT2's
Procomp Pro runner dual stabilizers
strokinpower is offline
post #3 of 23 Old 08-26-2013, 04:26 AM Thread Starter
will the factory 250 shocks work with these 4" blocks? or do you need new ones?
Casey
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #4 of 23 Old 08-26-2013, 07:37 AM
Quoted: 214 Post(s)
They should work because the factory F250 and F350 shocks are the same part number
Keith
AFE Intake
Sct x4
35" Toyo AT2's
post #5 of 23 Old 08-26-2013, 08:46 AM
broncojason's Avatar
Correct, the rear shocks will work.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #6 of 23 Old 08-28-2013, 01:40 PM
JRW6.7's Avatar
I used the 4" Readylift kit on my 2011 and it looks great. Installation was pretty easy with the help of my 9 yr. old son. You just need extra tall jack stands, and an impact driver came in handy.
JRW6.7 is offline
post #7 of 23 Old 09-08-2013, 08:27 PM
Is this what I want? IT says 5" which seem like it would be too much without the front level kit. I just want to have the rake of a 350. Free shipping to USA and Canada for ReadyLift 66-2015 Suspension Rear Block and U-Bolt Leveling Kit 5" | TDot Performance
suprathepeg is offline
post #8 of 23 Old 09-09-2013, 03:14 AM
Quoted: 214 Post(s)
No 5" is too much. You want a 4" block
Keith
AFE Intake
Sct x4
35" Toyo AT2's
post #9 of 23 Old 09-09-2013, 03:16 AM
if you have the long bed does the driveshaft have to be shimmed?
2011 F260 6.7 CC 4x4 LB
gsxr1300 is offline
post #10 of 23 Old 09-15-2013, 09:41 AM
I just came across this:
TSB 13-03-08 – 2011 – 2013 F-250 Super Duty 4X4 – Rear Of Vehicle Sits Lower Than Expected Under Light Loads
Some 2011 – 2013 F-250 Super Duty 4X4 vehicles may exhibit a customer concern of lower than expected rear
suspension height under light loads. Follow the service procedure in this TSB to correct the concern by adding a 10
cm (4”) spacer block, along with additional components.
