Need help lift and tires! Firestone air bags and ford's 5th wh. hitch 1st. - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-29-2013, 01:05 AM Thread Starter
pirogue's Avatar
I have a 13' 250 CCSB with the ford 5th wheel hitch waiting to be installed, and waiting on Firestone airbags to arrive and install. Seeking advice on tire size and level kit that won't hurt fuel mileage. I need direction on rear lift since I'm installing airbags and a good tire selection using stock 20" lariat rims.
The truck is Blue Jean/beige Lariat ultimate pckg, and just looking for a little more sportier look while still having to tow 14k 5th wheel.
Sent from AutoGuide.com App
05' 250 SB SRW, JMS SCT, INSIGHT CS, 4" MBRP TURBO BACK, ARP STUDS, 2" LVL w/BILSTEINS, EGR delete, replaced oil cooler, zerex EC-1, blue spring mod, coolant filter
13' F250 CCSB CLAZZIO SEAT COVERS, AFE CAI, TRIFECTA BED COVER
pirogue is offline
post #2 of 9 Old 07-29-2013, 01:49 AM
BIG Laing's Avatar
Both a leveling kit and bigger tires will hurt MPG.
If you still want that sporty look, without killing mpg too much stay closer to the 275mm wide tires that come on your truck stock. Maybe LT295/60R20, I would stay away from any 12.5"/305mm+ tires.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 9 Old 07-29-2013, 01:55 PM Thread Starter
pirogue's Avatar
Thanks for the Reply Big Laing, I will keep that in mind while tire searching!
Does anyone know if the Firestone RideRite bags assist in raising the rear to accommodate a 2" level kit with out sacrificing ride quality or is it best to add the rear blocks and keep the bags deflated while empty?
pirogue is offline
post #4 of 9 Old 07-29-2013, 04:03 PM
chodifer's Avatar
If you put a level kit you will most likely have to add F 350 blocks. for actual level as the 250's sit pretty level stock. If you air the bags right up it will ride really rough. What firestone's are you installing. I read somewhere the 2535 needs upper bracket to be modified because the hole is off about 1/2". I put the on leaf style firestones last week but i do not have a hitch.
chodifer is offline
post #5 of 9 Old 07-29-2013, 05:02 PM Thread Starter
pirogue's Avatar
I believe they are the 2535's, I think but not sure they are correcting them and that's why they haven't arrived? We'll see.
I did come across where someone did the bags and level lift then bought the blocks for a better ride.
pirogue is offline
post #6 of 9 Old 07-29-2013, 05:14 PM
broncojason's Avatar
Be careful using the word "sportier" around here, u may get flamed!
Lol, just playing.
I leveled my truck before I put tires on and watched the MPGs very close before and after, and didn't see any difference at all. Tires on the other hand, I dropped an easy 3+ MPGs!
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #7 of 9 Old 07-29-2013, 05:30 PM
BIG Laing's Avatar
For an even better ride look into Carli 6 leaf add a pack instead of an f-350 block. It produces 2" of rear lift (which is perfect to match your 2.5" leveling kit). Also helps cut down on axle wrap / wheel hop over just a taller block...
post #8 of 9 Old 07-29-2013, 07:23 PM Thread Starter
pirogue's Avatar
Thanks again!
pirogue is offline
post #9 of 9 Old 07-30-2013, 09:58 PM
Tim250's Avatar
^X2
2013 F-250 CCSB Fx4 3.55 Lariat, 17x9 -12mm Fuel Hostage on 315/70 Duratracs, Weather Tech mats, Ellis light bar w/ 8" KC HID's, Carli 2.5" Lift
Tim250 is offline
