Will it fit (KMC XD Misfits 20x9 with 5" backspacing) - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 8 Old 07-27-2013, 07:44 AM Thread Starter
Will KMC XD Misfits 20x9 with 5" backspacing work on a stock, non-leveled 2011 f350 with fx4 package. I currently have the stock 20" rims and tires (265/65r20 which are 33.6x10.43)
I was looking at Toyo M/T (315/60r20 which is 34.9x12.4x20)
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #2 of 8 Old 07-27-2013, 11:59 AM
BIG Laing's Avatar
So stock is 8" wide 6.25" backspacing.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 8 Old 07-27-2013, 01:11 PM Thread Starter
So the tire will stick out further past the fender 1.25" roughly?
Seeing as the point of the hub and lug nuts would decrease in area with the aftermarket rims?
Would it work?
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #4 of 8 Old 07-27-2013, 01:24 PM
BIG Laing's Avatar
Not sure how much past the fender on your truck. The 1.25" would be how much further the inside rim face will be sticking out then stock. The outside rim face would be sticking out 2.25" further out then stock. ( since the rim is 1" wider then then stock)
I don't know if your truck will clear that... I know on 08+ it's pretty close.
post #5 of 8 Old 07-27-2013, 02:31 PM Thread Starter
I wonder if I can find anyone with the same setup :[ the 08-2010 you can?
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #6 of 8 Old 07-27-2013, 03:31 PM
Use this tire/wheel calculator: I have already set the left column up for the stock 20" wheels, with the 275/65R20s that come on the lariats: Just input your new wheel/tire combo on right side, and it will tell you all the differences, like how much further it sticks out, diameter, everything: Wheel-Tire size comparer - RIMSnTIRES.com
You will need a level kit to clear properly, I have wheels and tires of the same dimension, had to trim a bit of the fender liner to get "zero rub"
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #7 of 8 Old 07-28-2013, 08:40 AM Thread Starter
You are leveled or stock? If I went to a less wide of a tire would it make a difference? Toyo makes these as well LT275/65R20 (34X11.00R20)
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #8 of 8 Old 07-28-2013, 11:03 AM Thread Starter
I might just level my truck and if anything is needed for warranty work I'll remove leveling kit and throw on stockers?
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
