2012 Daytime running lights - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-17-2013, 07:53 AM Thread Starter
We just bought a 2012 F350 xlt. Our headlight swith is just a 3 position switch, with off, running lights, and lights on, no auto mode. We bought it used, and we were told it came out of Canada. When you put the truck in drive, or reverse, the headlights come on, even if the switch is only in the running lights position. Is there a way to disable this, without having the truck throw a code, or doing anything that will jeopordize the warranty? Our truck is bone stock, with no add on's, tuner, or anything. As far as we know, it is exactly the way it came from the factory.
Quadstar is offline
post #2 of 3 Old 06-17-2013, 10:32 AM
GregsSD's Avatar
Garage
Look in your manual to see if there is a DRL fuse, if there is then all you have to do is pull out the fuse.
If there is no fuse for the DRL's, then you can take it in to the dealer and have them program your trucks computer to disable them.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 3 Old 06-17-2013, 03:31 PM
why don't you want them on?? its standard here in canada
Bopper is offline
