Widest tire - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 4 Old 12-27-2012, 05:48 AM Thread Starter
Widest tire
on stock 17'' rims? Just checking in to see if i can get 33 x 12.50 on stock 17'' rims?
greenmntboy is offline
post #2 of 4 Old 01-04-2013, 02:45 AM
2013Platinum's Avatar
I just put 35x12.50 on my stock 20s. Same width as the 17s. Completely stock suspension no rub.
A 33x12.50 is actually a smaller tire than comes on these trucks stock
2013Platinum is offline
post #3 of 4 Old 01-04-2013, 03:57 AM
BIG Laing's Avatar
Just make sure the tire you are getting is approved for the wheel width you have. I would assume its 8" wide like the 18" and 20" wheels. But I am not positive, so double check it. The size of the tire your looking at is not an issue with rubbing or clearance.
12.5" is wider then any tire that comes stock on our trucks! And only the 20" wheel trucks come with a taller tire (34.8"). The 18" wheel trucks have a 32.8" tall tire. Once again not sure about the 17" wheels.
Hope this helps.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #4 of 4 Old 01-04-2013, 05:11 AM Thread Starter
thank-you for the information it helps alot
